Inline Fuel Filter? - Club700XX - Honda TRX700XX Forum
post #1 of 10 Old 11-09-2009, 11:33 AM Thread Starter
Inline Fuel Filter?
Ok! this weekend I took the fuel pump apart and noticed the filter to be dirty, not clog up but just dirty so have ordered a new one, my question is; has anybody installed an inline fuel filter and if so what kind did you use and where did you installed it. Since we do not have that much space to work with I'm looking at this one http://www.jegs.com/i/JEGS/555/15040/10002/-1# and am thinking about installing it between the fuel pump and the throttle body.
post #2 of 10 Old 11-09-2009, 01:36 PM
bkelley's Avatar
$30? That's pretty steep for a little in-line filter.
Tusk In-Line Fuel Filter - $1.49
Visu-Filter In-Line Fuel Filter - $2.99
Red '05 TRX400EX:
bkelley is offline
post #3 of 10 Old 11-09-2009, 02:32 PM Thread Starter
Cool! I'll go with those one.
Thanks
post #4 of 10 Old 11-09-2009, 04:19 PM
msg harmon's Avatar
Any filter in line before the pump would be helpfull of course.
The Patriotic 700xx. Invision Blaze of Glory graphics, Pro armor Dominator II bumper, DG Nerfs, Acerbis Hand Guards, Maxxis Razr Rears, Two Brothers Exhaust, P4 Power tip, Rocky Mountain Lexx EFI controller. AC six pack grab bar, GPS Mount.
(((Handicap Racing)))
msg harmon is offline
post #5 of 10 Old 11-09-2009, 06:08 PM
OzLinc's Avatar
I would think that installing before the fuel pump would be better as after the fuel pump the fuel is under pressure.
OzLinc is offline
post #6 of 10 Old 11-09-2009, 06:40 PM
BiFfMaN's Avatar
+1
the tank has a screen to block big stuff like cheese burgers...just need a element filter to stop the finer particles. Fuel should be clean after the pump.
Now most cars and other quads have a intank pump...a inline filter dont effect them much.
what would help is to know what the optimal fuel pressure is for our injector.
BiFfMaN is offline
post #7 of 10 Old 11-09-2009, 09:02 PM Thread Starter
Yeah! Thinking the same but wouldn't hurt it if you have one installed after the fuel pump, have more room to install one. That's why I was looking at the billet one since it's made for fuel injection system.
Thanks you all for the info
post #8 of 10 Old 11-10-2009, 12:32 PM
vfm2010's Avatar
Originally Posted by BiFfMaN View Post
+1
Sorry Biffman, I shouldn't have left my lunch on top of the tank. I won't let it happen again!
88 LT500R QUADZILLA
06 DVX400 (Son's)
06 TRX250EX (Wife's)
vfm2010 is offline
post #9 of 10 Old 11-16-2009, 08:17 PM
De700's Avatar
If your goal is to stop the funk before the fuel pump, I would think it should be installed from the drop hose from the tank to the Pump, if not your loosing the purpose of not having to replace the fuel pump filter as much or to keep that clean so its not so much a pain in the Tukus to change.
De700 is offline
post #10 of 10 Old 11-16-2009, 08:49 PM Thread Starter
Finally got my fuel pump kit and is ready to be reinstall, did install a fuel filter on the inlet side. Will test it out this weekend. Might drain the gas tank and check that filter out since it is apart.
