Optimizer Settings? - Club700XX - Honda TRX700XX Forum
post #1 of 21 Old 11-16-2009, 07:51 PM Thread Starter
Optimizer Settings?
I have the HMF slip-on with the HMF optimizer. I have been runnin it with the recommended settings from HMF but it is running to rich, So does anyone have any suggestions for different/better settings?
08xxrider is offline
post #2 of 21 Old 11-17-2009, 07:36 AM
What signs do you have it is running rich on those settings?
post #3 of 21 Old 11-17-2009, 10:29 PM Thread Starter
it has fouled out 2 plugs and its its not runnin real smooth i guess you could say, backfiring, things like that
post #4 of 21 Old 11-18-2009, 05:12 AM
If it's backfiring your a bit lean, can you post pics of the plug?
post #5 of 21 Old 11-18-2009, 02:26 PM Thread Starter
no cause i dont have either one of the plugs.. threw them away
post #6 of 21 Old 11-18-2009, 03:11 PM
Not necessarily, if he has unspent fuel coming out of the chamber then igniting later, it would back fire.
post #7 of 21 Old 11-18-2009, 04:47 PM
A lean back fire will happen in the intake. Happens on my stock dos equis every now and again. A rich condition back fire will come out of the exhaust.
Side note.. Thats why when you spray nitrous you have to add fuel. If you dont your engine goes lean and can have a nitrous back fire. = BAD DEAL. Spray nitrous and add the right amount of fuel you get GOOD DEAL.
Andy07 is offline
post #8 of 21 Old 11-19-2009, 08:23 PM Thread Starter
so does anyone have different set of settings they think would be better?
post #9 of 21 Old 11-19-2009, 09:25 PM
Yes, Get a PCIII
post #10 of 21 Old 11-26-2009, 08:22 PM Thread Starter
Where would be the best place?
