Motor won't rev - Club700XX - Honda TRX700XX Forum
 1Likes
post #1 of 11 Old 03-02-2015, 05:20 PM Thread Starter
Motor won't rev
Last fall I managed to twist my piston sideways in the jug. I took the motor apart myself and installed a 3mm stroker crank, 3mm big bore, stage 2 hotcam, big gun evo r exhaust, big gun header pipe, and a high flow intake. Now the motor won't rev, at first I thought it was the reverse rev limiter but I tested my wiring and my reverse switch and they all seem good. I have no idea what else it could be, anyone else experience this?
Farmboy is offline
post #2 of 11 Old 03-02-2015, 07:19 PM
Quoted: 252 Post(s)
Welcome to the club
I'm not for sure, but the rev limiter's will make the engine cut out at a certain rpm. Is that what yours is doing, or just not revving up? Like it starts up but just idles? You may need to include some more info, like what kind if any programmer you have and how it's set it.
M_Quick is online now
post #3 of 11 Old 03-02-2015, 10:50 PM Thread Starter
It's acting like it's in reverse at all times and will only rev that little bit but I can't find a problem with the wiring or the switch
Farmboy is offline
post #4 of 11 Old 03-03-2015, 06:37 AM
Quoted: 252 Post(s)
So it rev's a little and cuts out like on the rev limiter? Did you check the neutral switch assembly's, but the foot sifter?
Also still wondering about your fuel settings?
post #5 of 11 Old 03-03-2015, 11:08 AM Thread Starter
Yes it acts just like the rev limiter when your in reverse, but I disconnected the wire that plugs into the switch and tried it and it did the same thing.
The fuel settings I have not messed with yet. I didn't know if I would need a programer at all or not.
Farmboy is offline
post #6 of 11 Old 03-03-2015, 11:35 AM
Quoted: 62 Post(s)
From what it sounds like you've done to it yes, you would. I'm sure others will chime in as well. Just a exhaust you should put a programmer on it, so I'm sure with the stroke and bore it just compounds the lack of fuel.
mumbauer is offline
post #7 of 11 Old 03-03-2015, 12:21 PM
YES, you do need a programmer!... But, that is not what's causing your problem and I don't know what is... But at the end you will still need the programmer.
post #8 of 11 Old 03-03-2015, 01:33 PM Thread Starter
Ok what programmer would you suggest
Alex Dzyak likes this.
Farmboy is offline
post #9 of 11 Old 03-03-2015, 02:05 PM
Quoted: 252 Post(s)
You running stock exhaust too? I'd upgrade the exhaust, and defiantly get a programmer. I like the power commander 5, but then you will need a dyno tune. You can use the ehs box, and I'm sure they can get you squared away with the proper settings.
Not sure I follow the way way your testing the reverse and neutral switch assembly's.
post #10 of 11 Old 03-03-2015, 02:10 PM
Quoted: 62 Post(s)
He said he has the big gun evo r and header
mumbauer is offline
