700xx2008 hour meter - Club700XX - Honda TRX700XX Forum
post #1 of 7 Old 11-19-2009, 05:22 PM Thread Starter
can someone help me on a good hour meter to put on my 08 700xx?
post #2 of 7 Old 11-19-2009, 07:41 PM
The member listed below has one, Send em a PM
https://www.club700xx.com/vb/member.php?u=102
post #3 of 7 Old 11-20-2009, 01:16 AM
FiXXation's Avatar
I put Hardline Hour Meters (inductive type) on all three of our ATVs. I'm not sure they qualify as "good", but they count running time OK. They have a single wire that wraps around the spark plug wire 5 or 6 times, and a self-contained battery that keeps the display on all the time. They are attached with double-sided tape and a couple of screws.
I have no idea how long they may last. The display and electronics are sealed, and the battery is not replaceable. It's an easy install, however.
You can do a search on eBay and find prices all over the place.
FiXXation is offline
post #4 of 7 Old 11-20-2009, 07:09 AM Thread Starter
thanks for the info fixxation where did you mount the hour meter at on the 700xx?
post #5 of 7 Old 11-20-2009, 01:14 PM
tbird88,
I also have a Hardline and find it to be adequate. I mounted it under the left rear fender in the flattened area to the inside of the fender well. I placed it in a clear plastic box to keep it out of the sand, mud and whatever. It appears to be holding up ok but I would still like to have a full-up gauge pod. The cost and trouble to install that instrument is beyond my dollar threshold.
Good Luck on making a choice. By-the-way, I have 30 hours registered on it and it is still working.
post #6 of 7 Old 11-21-2009, 10:28 AM
Ditto that. I run Hardlines on all mine that dont come stock with a meter. It helps me keep track of the maintenance on them better. I suffer from a good case of sometimers disease (Sometimes I remember but most of the time I forget)
12 RZR XP900
bduncan1231 is offline
post #7 of 7 Old 03-20-2010, 10:56 AM Thread Starter
My hardline hour meter took a crap.I guess it got wet. Had it under seat guess it still got wet. Oh well,Ill see if they will warrany it. Its only 3 months old.
