700 xx fule issue - Club700XX - Honda TRX700XX Forum
post #1 of 12 Old 03-12-2015, 07:09 PM Thread Starter
700 xx fule issue
Hey Guys! I'm new to this thread, but thought i would see if any of you would know of my issue. I have a 700 xx i bought about 6 months ago, and its ran like a champ until the last month or so. When i go to crank it up it gets really sputtery and smokes a lot until i ride it for about 15 min then every thing clears up. I have to be on the throttle all the time or or will just shut off. it seems like its getting gas leaked in some how when it sits , then i have to burn it back out before it runs good again. I don't know much about fuel injection at all. maybe a fuel injector? any help would be greatly appreciated
freakybikefreak is offline
post #2 of 12 Old 03-12-2015, 07:20 PM Thread Starter
700xx fuel issues
post #3 of 12 Old 03-12-2015, 10:03 PM
Quoted: 252 Post(s)
Couple things what color is the smoke? Have you checked the spark plug, and air filter? Fresh hi octane fuel in tank? Any mods, like pipe programmer ect?
post #4 of 12 Old 03-13-2015, 10:33 AM Thread Starter
Its gray smoke. At first i thought it was oil, but it hasnt burned a drop between oil changes. I have a uni air filter full big gun exhaust with big gun programer. Cleaned air filter. Checked spark plug and its wet and black when i first pull it out. Run it 20 min then take it out again and its a nice brown.
post #5 of 12 Old 03-13-2015, 10:34 AM Thread Starter
I also run premium gas with a shot of sea foam every tank.
post #6 of 12 Old 03-13-2015, 04:56 PM
Quoted: 252 Post(s)
So did it run good for that 20 mins? Or sputter the 1st 15 like you said it was doing? Could of just been the semi fouled plug? Also if you ever take the tank off like when you adjust the valves, check & or clean the fuel filter in the tank.
post #7 of 12 Old 03-13-2015, 05:19 PM Thread Starter
No it runs like crap for the first 15 to 20 min. Its really hard to start also. It usually Back fires sevral times. Okay so the fuel filter is in the tank? I'v all ways looked for it but couldnt find it. I'l try that thanks!
post #8 of 12 Old 03-13-2015, 06:27 PM
Quoted: 252 Post(s)
There's also a filter in the pump. Seams like a weird issue your having. If your taking the tank off to check and clean the filter in the tank, it's attached to the pit-cock valve. Also might as well check and adjust the valves while the tank is off. Valves out of spec sometimes cause a hard start. I hope you figure it out, but at least it runs well after 15-20 mins.
post #9 of 12 Old 03-13-2015, 06:32 PM
Quoted: 252 Post(s)
fuel pump filter info
post #10 of 12 Old 03-14-2015, 09:27 AM Thread Starter
Sounds good I appreciate it. I havent adjusted the valves yet since i'v had it. Maybe the fule filter in combine with the valves will at least get it going better. Where do you buy a fuel filter? I cant seem to find one.
