popping on decel-stock pipe - Club700XX - Honda TRX700XX Forum
post #1 of 7 Old 11-23-2009, 12:14 AM Thread Starter
I recently purchased a used 2008 700xx and wanted to ask you guys if you think I have a problem. The bike is completely stock from what I can tell. When I let off the throttle with it reving high I get popping from the pipe. Is this normal or do you think there is a problem? I also think that there may be a little hesitation when I gun the throttle. I am not sure if this is normal either since I have never riden a EFI Quad before.
Thanks for the help.
Sallyman is offline
post #2 of 7 Old 11-23-2009, 07:00 PM
OzLinc's Avatar
Not really anything to do with the EFI. Any engine could have this issue.
Popping on deceleration can be two things, an exhaust leak or a lean condition down low in the rev range........I think it's the latter - lean.
It is generally thought that the XX is tuned lean from the factory to make it emissions legal.
If it has an exhaust leak thats easy to fix but the lean condition is only fixed with a tuner box like the PowerCommander.
OzLinc is offline
post #3 of 7 Old 11-23-2009, 07:12 PM
skier207's Avatar
I have a 2008 700XX completely stock I have never had it pop on decel ever, even letting off from high rpm. I have rode it from sea level to 9000ft elevation. After I put a fuel controller on it with the stock pipe still no pop. I would think you most likely have an exhaust leak.
skier207 is offline
post #4 of 7 Old 11-23-2009, 07:21 PM
09RappySE's Avatar
Quoted: 16 Post(s)
You may also want to adjust your valves, your exhaust valves may be too tight.
734 09 Raptor
Tuned by EHS Racing 78hp 55Tq
09RappySE is offline
post #5 of 7 Old 11-23-2009, 08:23 PM
IMO - this.
post #6 of 7 Old 11-23-2009, 11:08 PM
I agree with this also. I only rode my 700XX once while it was bone stock, but I did notice occassional popping on decel also, just enough to be annoying. Once I installed a pipe, power commander, and removed the airbox lid, the popping wnet away.
Doug
2004 TRX450R, 2008 TRX700XX
2005 TRX450R
1986 TRX250R
D Bergstrom is offline
post #7 of 7 Old 12-01-2009, 06:37 PM
engine popping when you let off the gas
mine does that also under deceleration pops you all should know what im talking about my 700xx is stone stock motor wise it may be the sorry prem unleaded down here in south alabama my 400ex did the same they dont do it every time you let off about 1 every 10 times i thin the gas sucks in my neck of the woods what kind of gas does everybody else run
