Sprocket Suggestions - Club700XX - Honda TRX700XX Forum
post #1 of 6 Old 03-19-2015, 01:52 PM Thread Starter
So after 6 years of owning my quad getting around to switching out the front sprocket and need some advice/experiences people have had with them. Currently my quad has 727 big bore kit, port/polished head with 5 angle grind on valves, stage 3 hotcam, two bros juicebox pro, and full fmf exhaust, so plenty of power. So the question is should i go down a tooth to 13 or up to 15. andddd go!
08honda700xx is offline
post #2 of 6 Old 03-19-2015, 06:30 PM
1st question is what size tires you running? If stock 22" rears personally I'd go up to the 15t. Mine right now has plenty of low end torque with the 14t. I plan to try a 15t this summer, but I stroked a standard bore and added stage3 cam. But in the end only you know how the quads reacts, and what you are wanting out of it.
post #3 of 6 Old 03-20-2015, 07:30 AM
Snoshoe's Avatar
true that, mine is stock, I put the bear claws on and went to a 13t, i do alot of work with it on the farm so the lower speed is easier on the stuff i tow and easier to check the fences.
2008 TRX700xx
13Tfront
Kenda Bear Claws 23x8x11
Custom 2" receiver
rear seat/ strorage box
Ground Hog Disk harrow kit
PEI fog lights
Snoshoe is offline
post #4 of 6 Old 03-20-2015, 09:13 AM Thread Starter
20x11x10 rears. Mainly wanting a mean trail machine. Most the trails I ride are twisty woods trails with alot of straights to open er up. Right now all the people I ride with dont stand a chance keeping up out of the hole or wide open. I ordered a 13t last night so going to see how that works. 15t may be ordered so I can compare.
post #5 of 6 Old 03-20-2015, 02:41 PM
If you rarely get into 5th then maybe go down a front tooth, if you spend a lot of time at high speed go up a tooth..
rappey is offline
post #6 of 6 Old 03-20-2015, 08:28 PM
20" and a big bore kit. My opinion the 13t is going to work that motor alot harder than needed. And when I ride tight trails I seldom use 4th let alone 5th gear. 3rd gear pulls to 40mph. And your alrdy given up top speed with the 20's, so unless your struggling now to keep it running in low gear, I'd leave the 14t on there. But try it out you may like pulling 3rd gear hole shots.
