Stroker/Big Bore - Club700XX - Honda TRX700XX Forum
 1Likes
post #1 of 14 Old 03-20-2015, 11:19 AM Thread Starter
Stroker/Big Bore
Anyone have both? Have a leaky seal on the crank case so if i tear it down I would like to make it a stroker along with the big bore i already have. Looked through the threads and really couldnt find anyone with both along with upsides and downsides of having both. I know when i put the big bore in with headwork it was a night and day difference resulting in having a hard time keeping the front wheels on the ground.
08honda700xx is offline
post #2 of 14 Old 03-20-2015, 03:40 PM
I have both. If it was a greaqt difference with the big bore then the stroker should be another big difference..
Cant say there are any downsides..
When you put the crank in rotate it with the piston in the bore as the crank may clip the piston skirt, which i resolved by grinding around 3-4mm from the skirt to clear the rotation of the crank..
Other than that, pretty easy.
rappey is offline
post #3 of 14 Old 03-21-2015, 10:35 AM
As above , watch the piston skirt hitting the conrod. The only downside is the programmer I have can't fuel the motor enough in the higher RPM's. Going to a PCV and getting her on the dyno.
Plus side is , I love this setup. Best mod after the Big 3.
post #4 of 14 Old 07-15-2016, 04:23 PM
Quoted: 141 Post(s)
I wish I had known about the piston hitting the counterbalance before I found out the hard way .
I then looked at the older piston that I had taken out , it had been hitting that one as well ,but just barely .
cataway is offline
post #5 of 14 Old 07-16-2016, 07:09 AM
Quoted: 141 Post(s)
does not hit now
cataway is offline
post #6 of 14 Old 07-16-2016, 08:16 PM
Quoted: 252 Post(s)
So what happened or what damage did it cause? And could you not hear the noise from it hitting, over the rest of the motor noise?
post #7 of 14 Old 07-16-2016, 08:33 PM
Quoted: 141 Post(s)
what happen is that I put in a stroker crank . after putting the camshaft back I was rotating the crank ,by hand , then there came a sudden stop . to late the damage was done . the piston in the pic is not the damaged one its a different piston ,it has been modified to miss the counter balancer .
cataway is offline
post #8 of 14 Old 07-16-2016, 10:55 PM
Quoted: 252 Post(s)
So it was noticeable atleast when turning by hand. I'm just curious because I had a stroker installed by someone else. I have readjusted the valves several times and haven't noticed what you described. Just hear the cam relief. I plan on redoing my top end one day, but hopefully will get another season or 2 on it 1st.
post #9 of 14 Old 07-16-2016, 11:52 PM
Quoted: 141 Post(s)
rappey had a problem with it .tho I don't know which piston he used and maybe who ever it was that did yours knew what to look for
cataway is offline
post #10 of 14 Old 07-17-2016, 01:56 PM
my piston was a vertex, as supplied with the stroker crank and barrel by cylinder works.
A piece of paper was included saying to check the piston skirt clearance, and to grind some out of the crank to crate the clearance...
Since my crank and bearings were already in i decided to file away the piston like you did.
rappey is offline
