what is the best air filter? - Club700XX - Honda TRX700XX Forum
post #1 of 6 Old 11-30-2009, 04:21 PM Thread Starter
what do you think the best air filter for a good price would be. im not sure if i want to get k&n because of the price, but i might anyways.
trx700xx08 is offline
post #2 of 6 Old 11-30-2009, 05:02 PM
gavineli's Avatar
Ive always heard good things about uni but never had any experiance with them myself
I have always used K+N without any problems and i ride in some realy dusty areas just make sure you got a good outerware on it
gavineli is offline
post #3 of 6 Old 11-30-2009, 06:29 PM
trx tas's Avatar
i run a pro design foam filter had no problems with it cost me $300 australian
trx tas is offline
post #4 of 6 Old 11-30-2009, 07:17 PM
I've always used a UNI and had no problems with it even in very dusty conditions. It has always stopped the dust/dirt even when it's way over due for a cleaning.
2007 Yamaha R1 Charcoal/Black
THREESVTS is offline
post #5 of 6 Old 11-30-2009, 07:35 PM
09RappySE's Avatar
Quoted: 16 Post(s)
Trust me the outerware does very little for fine dust, you may think it is not causing you any problems but, if you send in an oil sample for testing I bet you will think otherwise, I did and found that the K&N was letting through massive amounts of dirt detected in the oil, I have since then added a foam outerware to my K&N and will find out how it worked on my next sample, if it does not significantly drop the amount of dirt passing through the filter I will be switching to foam. For those interested in having their oil tested you can get this done at blackstone labs, it is $22 a sample but it gives you a world of info to protect your investment.
734 09 Raptor
Tuned by EHS Racing 78hp 55Tq
09RappySE is offline
post #6 of 6 Old 12-01-2009, 08:50 AM
An oiled foam filter is just about the best protection you can get.
