The Great Synthetic Debate - Club700XX - Honda TRX700XX Forum
post #1 of 8 Old 04-08-2015, 02:00 PM Thread Starter
Quoted: 6 Post(s)
Well guys and gals. The new riding season is upon us and oil change time is here yet again. I'm always wondering if I should run synthetic or not and can't find a definitive answer in the previous billion posts. So my question is. Should I run synthetic in the ol girl or not. I usually run mobil 1 mx4t synthetic 10w40 but have considered changing to good old fashioned honda gn4 10w40. What does everyone think? Ive never had a problem running synthetic in anything i own! But these wet clutch systems are pretty sensitive imo. Fellow 700xxers please chime in.
700xx
Ehs programmer
Ehs lid
13t sprocket
Trail tech vapour
Traxion fronts
Kenda kutter rears
Violatorpriest is offline
post #2 of 8 Old 04-08-2015, 04:15 PM
Quoted: 252 Post(s)
Was using the Mobile 1, switched to this stuff. No clutch issues, but lost top end!
Castrol POWER RS - Motorcycle & Scooter Engine Oil | Castrol United States | Products | Home
post #3 of 8 Old 04-08-2015, 11:15 PM
I run Rotella T and T6 in my 400ex and Outlaw. No problems here. It's good oil that is also affordable enough to allow me to change it often, something that the Outlaw requires.
Outlaw 525 IRS
Save the Oregon Dunes!
Rkangel is offline
post #4 of 8 Old 04-09-2015, 10:14 AM
CRAVEN7786's Avatar
I have been running the Honda HP4S synthetic oil in mine for quite some time now, with no problems. Just be sure it is the red bottle, not the grey bottle since the grey bottle has moly in it, which will fry a wet clutch. To elaborate, I had a shift fork bend from a stick hitting my shifter so the engine was completely torn down. The guy working on it said everything looked almost new, in an engine with easily 500 hours on it.
CRAVEN7786 is offline
post #5 of 8 Old 04-11-2015, 01:52 AM Thread Starter
Quoted: 6 Post(s)
I used lucas oil one time and beleive it caused clutch issues. As well I have tried Rotella t6 synthetic and thought it was causing clutch slippage as well. Never had problems with mobil 1 tho
700xx
Ehs programmer
Ehs lid
13t sprocket
Trail tech vapour
Traxion fronts
Kenda kutter rears
post #6 of 8 Old 04-12-2015, 09:54 PM
Quoted: 4 Post(s)
I pretty much content with Mobil 1. What is important is that you replace your oil and filter religiously and surely you will be safe.
kartl is offline
post #7 of 8 Old 05-16-2015, 06:46 PM
Running Bel Ray Mineral 10w40 now. I change my oil after every weekends race which could between 2.5 hours to 8 hours.
post #8 of 8 Old 05-17-2015, 09:03 AM
Scallywag's Avatar
Im a big synthetic believer. I have been using Amsoil and liking the results.
Scallywag is offline
