Piston recommendations - Club700XX - Honda TRX700XX Forum
post #1 of 11 Old 04-16-2015, 11:22 AM Thread Starter
Quoted: 33 Post(s)
Hi guys,
End of March I was riding and the quad stalled and did not want to restart. It finally restarted and made a loud rattleing sound so I shut it off and called the wife to come pick me up. This past week I finally have felt good enough and had a little time to open it up and find out what was wrong. What I found was scoring on the intake side of the piston and cylinder. I got a new stock cylinder off ebay for $180 shipped. Now I need a piston. Can get a Wiseco stock compression ratio for just under $130. I can get a JE piston with 11:0:1 compression for $180 shipped.
Stage 3 Hotcam is on the way.
Is the higher compression worth the extra $50?
Correction: after a little more research the stock compression is 10:0:1, Wiseco is 10:5:1.
Luecker is offline
post #2 of 11 Old 04-17-2015, 11:29 AM
My opinion would be for the JE piston with 11:0:1 compression for the simple reason... you've already got the Stage 3 Hot Cam on the way... Might as well go higher on the compression while you're at it. Just remember you're gonna need to run with higher octane fuel with 11:1 compression.
post #3 of 11 Old 04-18-2015, 08:25 PM
I'm glad somebody cashed in on the cylinder deal. I wish I would of found one that cheap when i needed it. Someone has a old beat up one on ebay for $300, been on there for awhile now, lol.
https://www.club700xx.com/vb/194233-post7.html
I went with the Wiseco piston myself, and I personally can't see the $50.00 difference in the slight compression. As for what I've herd thou the CP Carrillo pistons are top notch! Oh and good luck with that cam.
post #4 of 11 Old 04-19-2015, 10:11 PM
blakjak619's Avatar
Quoted: 35 Post(s)
Only run CP in my racer
blakjak619 is offline
post #5 of 11 Old 04-21-2015, 12:09 PM Thread Starter
Quoted: 33 Post(s)
I ended up going with the JE. Received it today.
I also received the Hot Cam today. M_Quick, is there an issue with the stage 3 Hot Cam?
Luecker is offline
post #6 of 11 Old 04-21-2015, 01:35 PM
If you search around here on the hot cam 3. You will find several hard start issues. I have also herd some of them are indexed wrong, making it impossible to time the quad. Which could also be a reason for hard starts. I think I found out the hard way, why the Web cam's cost more and require H/d springs and hard welded rockers.
post #7 of 11 Old 06-26-2015, 08:57 PM Thread Starter
Quoted: 33 Post(s)
Time for an update. With my busy work and family schedule it has been a challenge to get this rebuild done. The JE piston rings are not a direct fit. They send them a little large so you can file them down for your preferred ring gap. Got everything buttoned up and then had to disconnect the negative battery cable to attach the Power Commander V wire. I must have over tightened the cable to the terminal on the Antigravity battery because in the process of removing it, the cable wrapped around the corner of the battery case breaking it in the process. Sent it off to Antigravity a couple weeks ago and they are going to recase it and send it back to me. In the meantime I charged and installed my oringinal battery and finished installing the PCV, auto tune and put the gas tank on so I could take it on a break in ride. M_Quick had me a little worried that it may not start very well with the stage 3 Hotcam. It started up pretty easy. Took it for a quick little ride on Monday night. My butt dyno is very happy with the power increase with the piston and cam. So Wednesday I loaded the quad in the back of the truck and when tying it down I noticed grease on the rear arm. Looked closer and my left inboard joint boot has a hole in it. So I figured I would go ride it anyway and just stay out of the water puddles. I drove 20 miles to my local riding area and unloaded the quad and went to start it and the battery was too weak to start it. Put it on the charger tonight it was only at 37%. Hopefully I can ride it on Sunday so I can recheck the valve clearances and finish putting the quad back together.
Luecker is offline
post #8 of 11 Old 06-27-2015, 07:10 AM
Quoted: 143 Post(s)
there is a paper that came with the cam giving valve lash for the hotcam , what does it say the valve lash should be ?
cataway is offline
post #9 of 11 Old 06-27-2015, 11:33 AM
It's the same as stock. I was wondering how the battery dies this time of year from Mon to Weds?
post #10 of 11 Old 06-27-2015, 12:01 PM Thread Starter
Quoted: 33 Post(s)
Because it is old and has been sitting for the last year and a half. Battery is more less shot, but will have to work until I get the Antigravity battery back.
Luecker is offline
