No Lights Help - Club700XX - Honda TRX700XX Forum
post #1 of 6 Old 04-22-2015, 03:46 PM Thread Starter
No Lights Help
Machine was winterized in the garage this year. Took it out yesterday to prepare for a atv trip at the end of May. Headlight high/low doesn't work. Taillight doesn't work. Brake light is fine. Fuse is good to go. What's my next step/check? Any help appreciated much. Thanks.
kward is offline
post #2 of 6 Old 04-22-2015, 04:01 PM
TheZombieAK's Avatar
Check your wiring from the switch to the main plug then to the fuse box. If there is no chaffing, rubs, etc. get a 12v light meter and start at the fus box and work your way around.
Hate to sound like a jerk, but make sure your bulbs are good still, you didn't mention checking them so just a thought also.
TheZombieAK is offline
post #3 of 6 Old 04-22-2015, 04:13 PM Thread Starter
Thanks
kward is offline
post #4 of 6 Old 04-22-2015, 04:42 PM
Where was quad stored? Almost sounds like varmint damage.
post #5 of 6 Old 04-22-2015, 05:57 PM Thread Starter
In the garage. Honda dealer said that. Gonna investigate later tonight. Thanks
kward is offline
post #6 of 6 Old 04-23-2015, 08:21 AM
Quoted: 62 Post(s)
That happened to mine...turned out I needed a new switch. The wires in the switch separated but still worked for some time. Maybe over winter it corroded enough to stop working. Easy enough to take the two screws off and check the wires in there.
mumbauer is offline
