intalling PCV - Club700XX - Honda TRX700XX Forum
post #1 of 7 Old 12-05-2009, 03:23 PM Thread Starter
intalling PCV
ok..have the PCV all the way installed exept the wire tap. what whire do you connect it to? it says in the install guide to hook the wire tap to the yellow/blue wire, well there is a brown/black, brown/yellow, brown/blue and a black/blue wire...which one do I hook it to?
by the picture in the manual it is connected to the second terminal from the left which would be the brown/yellow wire (I am assuming it is this one to connect it to) however I just wanted to make sure first.
hobby10k is offline
post #2 of 7 Old 12-06-2009, 01:42 PM Thread Starter
Pcv
anyone know? I tried calling dynojet but they are not open on weekends.
hobby10k is offline
post #3 of 7 Old 12-06-2009, 04:55 PM
Do a search, there are other post concerning this issue.
post #4 of 7 Old 12-06-2009, 06:58 PM
I'm away offshore to look at my bike and don't recall which one. Use a test light and find one that comes on with the ignition
post #5 of 7 Old 12-06-2009, 07:34 PM
OK yellow / blue goes from map/tp sensor to the ECM. You will find at the front under the light . where all the plugs are. If you look from the front at the wiring . It is the first plug on the right. It's the plug under the clear plastic covering.
post #6 of 7 Old 12-07-2009, 09:08 PM
vfm2010's Avatar
I can look at mine tomorrow after work.
88 LT500R QUADZILLA
06 DVX400 (Son's)
06 TRX250EX (Wife's)
vfm2010 is offline
post #7 of 7 Old 12-07-2009, 10:04 PM
Same exact wire as the PCIII:
Here's the instructions. (you'll need a .pdf reader)
yellow/blue wire.
