Thermostat question - Club700XX - Honda TRX700XX Forum
post #1 of 9 Old 06-03-2015, 02:33 PM Thread Starter
Quoted: 4 Post(s)
Thermostat question
How would I be a able to check if the thermostats bad? I have honestly no idea what's going on with my overheating issues.
jonLAY19 is offline
post #2 of 9 Old 06-03-2015, 03:35 PM
If you do not have the service manual yet then download it from this site Service Manual Downloads - All years - Honda ATV Forum. Look under the cooling system section, it shows how to remove and test the thermostat.
DIEB4ME is offline
post #3 of 9 Old 06-03-2015, 04:28 PM Thread Starter
Quoted: 4 Post(s)
Thanks man! Will do when I get on my computer!
jonLAY19 is offline
post #4 of 9 Old 07-04-2015, 12:14 PM Thread Starter
Quoted: 4 Post(s)
Well I think I figured out the overheating problem, however it seems the xx is bogging in 4th and 5th. I don't know if I'm going to keep the xx for much longer. Too many problems keep popping up
jonLAY19 is offline
post #5 of 9 Old 07-04-2015, 08:13 PM
Quoted: 143 Post(s)
why does it even have a thermostat ?
cataway is offline
post #6 of 9 Old 07-05-2015, 12:40 PM
Quoted: 33 Post(s)
Have you cleaned the radiator fins? You should be able to see light through the radiator. Mud could be preventing air from getting through the radiator.
Luecker is offline
post #7 of 9 Old 07-05-2015, 03:09 PM
Quoted: 143 Post(s)
bogging ?? to much gas ......or to little ? if it were running lean it would be hotter . is the head pipe blue ?
cataway is offline
post #8 of 9 Old 07-05-2015, 05:48 PM Thread Starter
Quoted: 4 Post(s)
Im stupid, it wasnt bogging i just forgot to put the airbox cover back on but the head is black/ maybe blue? ill have to look. and its still over heating, less often. its like the resi isnt putting antifreeze back into the rad and its all spraying out of the overflow.
jonLAY19 is offline
post #9 of 9 Old 07-05-2015, 05:49 PM Thread Starter
Quoted: 4 Post(s)
I have no idea, im about to go power wash it so ill let you know, but its also losing antifreeze... so
jonLAY19 is offline
