Radiator fan - Club700XX - Honda TRX700XX Forum
post #1 of 7 Old 06-18-2015, 11:00 AM Thread Starter
Radiator fan
When is the radiator fan supposed to start running? Does it start when the key is turned over? Or only at certain temps? How can I check to be sure the fan is working properly?
adouga is offline
post #2 of 7 Old 06-18-2015, 11:45 AM
Quoted: 62 Post(s)
Key must be on and at temp. Mine usually turns on after idling for a little while (5-10 minutes I think).
mumbauer is offline
post #3 of 7 Old 06-18-2015, 10:54 PM
My fan seldom if ever runs while riding. Idk exact temp but if your lights not on and it's not boiling over into the over flow, your over thinking it imo.
post #4 of 7 Old 06-18-2015, 11:04 PM
Amerikanzero's Avatar
Quoted: 22 Post(s)
It usually doesn't kick on until after you have let it idle for a Great length of time or after having ridden it for a while. The fan is there too help the cooling during normal operating temps. By normal I don't mean just putting around. This is why it is liquid cooled in the first place.
I agree with M_Quick, you may be overthinking it.
Where you come from is gone. Where you thought you were going to weren't never there, and where you’re at ain't no good unless you can get away from it!
Amerikanzero is offline
post #5 of 7 Old 06-19-2015, 02:24 PM Thread Starter
Thanks for the replies. I hope I am over thinking it. I just have not noticed the fan kick on and don't want to overheat the engine and cause damage. On my other atv, grizzly 700 eps, the fan kicks on fairly quickly after idling or riding.
adouga is offline
post #6 of 7 Old 06-19-2015, 03:16 PM
If parked and at a idle, I'd say it should come on in 15 to 20 mins. But why wait that long. Just warm it up a min, ride the hell out of it for 30 mins. Or so. Shut it down, then turn key on but don't start quad. You should hear fan running then.
post #7 of 7 Old 06-19-2015, 04:06 PM
Quoted: 22 Post(s)
Here is a link to a good thread in this forum. It should put your mind at ease.
https://www.club700xx.com/vb/8-motor-...54/topics/7698
