Noise coming from my gear reduction, does this area take its own gear lube?? - Club700XX - Honda TRX700XX Forum
post #1 of 3 Old 07-08-2015, 11:39 AM Thread Starter
MY trx700 has some tranny noise while driving but stops when i pull the clutch in or let off the throttle, noise is coming from the reduction gear side, what lubes that area? sounds dry like those gears arent getting oil, is this area sealed off from the tranny and require its on gear lube? this area on my xr650s would be where my front sprocket is, but on the trx its been set up for the reduction gearing.
Grizzly_Customs is offline
post #2 of 3 Old 11-08-2016, 08:45 PM
Recently purchased a 700xx and I just noticed that exact noise today. It seemed to go away after riding a little but still discomforting. Just curious if you every found anything out on this. Thank you
jbarbs96 is offline
post #3 of 3 Old 11-11-2016, 01:32 PM
Quoted: 252 Post(s)
I'd do a oil & filter change. Making sure to install oil filter the correct way. There is no separate lube for anything else other than oil and the coolant.
M_Quick is online now
