Does anyone reommend the Hot cams 3? Or is it a waste of time and effort - Club700XX - Honda TRX700XX Forum
post #1 of 4 Old 07-19-2015, 09:12 PM Thread Starter
Quoted: 6 Post(s)
Just looking for my next mod. Was thinking about the hc3 but have heard people have hard start issues. Is it worth doing or a waste of time. Thanks guys
700xx
Ehs programmer
Ehs lid
13t sprocket
Trail tech vapour
Traxion fronts
Kenda kutter rears
Violatorpriest is offline
post #2 of 4 Old 07-20-2015, 01:19 PM
The hard start issues are usually a result of the higher compression... You'll need a better battery to give you more cranking power... CCAs (Cold Cranking Amps) And, make sure your compression release is installed and working correctly.
post #3 of 4 Old 07-20-2015, 07:41 PM
Go for the HC2 cam instead. HC3 is better for bigger cc's .
Had a HC3 on stock bore and stroke and it was no better than a stock cam. Add 3mm stroke and 3mm bore , this is a great cam.
post #4 of 4 Old 07-21-2015, 03:33 PM
says on the box that you have to run them in for whatever at no less than 3000 rpm? Any idea why ?
rappey is offline
