Fuel valve? - Club700XX - Honda TRX700XX Forum
post #1 of 11 Old 12-19-2009, 12:00 AM Thread Starter
Fuel valve?
I purchased my XX used so I don't know if there is supose to be a handle to control the fuel valve. I can see the valve under the tank but it seems way back in there and not easy to get to. Am I missing some linkage? All I can see is a small square drive on the valve. Is there 3 positions? Is there a reserve? Also, I removed the seat looking for the tool pouch/owners manual and didn't see it. Does anyone know where to look for it? The owners manual would definitely help. Thanks.
Sallyman is offline
post #2 of 11 Old 12-19-2009, 02:32 AM
I would say the fuel lever has fallen off. A few guys here have had the same problem.
You would need to order:
16963-HP6-AOO Lever, Petcock
90116-GF8-OOO Screw
Apply a dab of medium strength Loctite to the screw , when fitting and you should be alright.
post #3 of 11 Old 12-19-2009, 03:10 AM
BiFfMaN's Avatar
Cheers for baxter on the part number you will need.
The tool Tube should have been under the seat towards the back.
BiFfMaN is offline
post #4 of 11 Old 12-19-2009, 05:29 AM Thread Starter
Thanks for the info guys.
Sallyman is offline
post #5 of 11 Old 12-19-2009, 02:29 PM
Sallyman,
While you are installing the fuel valve plastic handle you will probably want to put a small dab of BLUE Loctite on the threads of the screw in the center.
"Baxter" mentioned "medium". If you ("Sallyman") are not familiar with the Loctite products, DO NOT use the "Red".
Baxter, I am not trying to "steal your thunder" but as you look through the myriad of thread securing products available on the market, I would be concerned that the wrong material could be used.
post #6 of 11 Old 12-19-2009, 02:35 PM
BiFfMaN's Avatar
Green is also Awsome..hahaha
BiFfMaN is offline
post #7 of 11 Old 12-19-2009, 08:41 PM
Sid ,I could not remember the color, but thank you . it is the blue Loctite 243 in the UK.
post #8 of 11 Old 12-20-2009, 03:20 AM
BiFfMaN's Avatar
we use 242 on aircraft..good stuff
222 for the smaller stuff
BiFfMaN is offline
post #9 of 11 Old 12-22-2009, 01:04 AM Thread Starter
Anyone have any recomendations for where to buy OEM parts?
Sallyman is offline
post #10 of 11 Old 12-22-2009, 12:02 PM
Well, besides your local stealership, you could go to....
http://www.babbittsonline.com/
For OEM everything. Yes, I know that I stole the term "stealership" from another person's post, but the term is accurate... so I used it.
P.S. I just checked babbits and the fuel lever and screw are $14.87 plus shiping... if those are the parts you were referring to anyway.
