Oil leak - Club700XX - Honda TRX700XX Forum
 1Likes
  • 1 Post By M_Quick
post #1 of 6 Old 08-10-2015, 10:23 AM Thread Starter
Quoted: 6 Post(s)
Oil leak
My trx have bluish smoke coming from the exhaust.. My mech told me that its burning oil.. so he says it can be the valves seals.. he recomended me to use a ATP AT-205 Re-Seal Stops Leaks so that we didnt have to open up the engine.. what do you guys think? should i change the seals and at the same time the valves???
cartuho is offline
post #2 of 6 Old 08-11-2015, 11:46 AM
blakjak619's Avatar
Quoted: 34 Post(s)
I personally wouldn't use anything like that but sounds like you at least have dirt in the piston rings. At the 2014 Baja 500 we sucked some dirt through the intake on a fresh top end and it ended up needing to be replaced.
blakjak619 is offline
post #3 of 6 Old 08-11-2015, 02:13 PM
Quoted: 252 Post(s)
Originally Posted by blakjak619 View Post
I personally wouldn't use anything like that.
X2, and I can't believe a Tech recommended this method. He must be to busy or just not wanting the work?
blakjak619 likes this.
post #4 of 6 Old 08-11-2015, 02:20 PM
blakjak619's Avatar
Quoted: 34 Post(s)
Or he doesn't know what he is doing...
post #5 of 6 Old 08-11-2015, 08:25 PM
Quoted: 252 Post(s)
Or just plain scurred!
post #6 of 6 Old 08-12-2015, 12:16 PM
On the basic research I did on this stuff, I didn't find anything that says it's safe for a wet clutch. So, I wouldn't use it. Besides the reasons stated above.
