Coolant leak? - Club700XX - Honda TRX700XX Forum
 1Likes
  • 1 Post By roadkill
post #1 of 5 Old 08-13-2015, 07:35 PM Thread Starter
Quoted: 9 Post(s)
Coolant leak?
Within the last month I purchased a 700xx and it is the first quad I have used that was liquid cooled. When I ride i can hear a hissing sound once in a while (kinda like water hitting the header). I was wondering if this is a normal thing or something that should be addressed. I can specifically hear it when im cruising in second gear or pull off the throttle. Any help with fixing this would be greatly appreciated.
Jc0620 is offline
post #2 of 5 Old 08-15-2015, 11:53 AM
You should not hear any kind of hissing sound... Things to check: Running hot? Coolant loss? Loose connections on cooling system? Pinhole leaks in hoses? But, YES by all means check it out.
Baxter likes this.
post #3 of 5 Old 08-15-2015, 08:11 PM
Quoted: 5 Post(s)
Keep lookin it will tell you sooner or later!!!!!!!
Elmer is offline
post #4 of 5 Old 08-16-2015, 09:10 AM Thread Starter
Quoted: 9 Post(s)
I tightened all the hose clamps down and it didnt do anything. I also rerouted the overflow line so i could c it and nothing came out while riding.
Jc0620 is offline
post #5 of 5 Old 08-16-2015, 12:05 PM Thread Starter
Quoted: 9 Post(s)
I also have ran a tank of gas thru it so far. Mayb 2 at the most. Would that b enough running time to c if ther was oil mixed with the coolant? Right not i do not c any which is a good sign.
Jc0620 is offline
