Alba stage 3 - Club700XX - Honda TRX700XX Forum
post #1 of 12 Old 12-22-2009, 08:04 PM Thread Starter
kelodwro's Avatar
Alba stage 3
Looks cool... little expensive, but I am sure it is worth it...
Anyone use it?
Good?
Bad?
Ugly?
Thanks for any input, I will do the Fox's first but like to think ahead (maybe I will do it last part of winter...)
'08 700XX
Power:
EHS bullet box (Thanks Eric!)
Full HMF exhaust system
K&N air intake
Handling:
Flex bars 14* 31" Quad racer
Bling:
Honda Racing MX front bumper
IMS fuel tank
Red Silicon radiator hoses
Gripper seat
kelodwro is offline
post #2 of 12 Old 12-23-2009, 01:11 PM
there are a few guys on here with it. and yea there some bad a** quads 50+hp. the bad is its pumped up now so theirs a higher risk of part failure sooner. and you HAVE to run race fuel with high compression. u can still get a stage 3 kit and get a lower compression piston but will not see as high of hp #'s hope that helps
post #3 of 12 Old 12-23-2009, 09:10 PM Thread Starter
kelodwro's Avatar
i would just buy some octane booster....
and would go with the "endurance/ desert" stage 3.... not sure if there is a difference, but I like the word endurance...
'08 700XX
Power:
K&N air intake
Handling:
Bling:
IMS fuel tank
Gripper seat
kelodwro is offline
post #4 of 12 Old 12-23-2009, 09:20 PM
Negative, Do not use octane booster. If you read the bottle it only raises it tenths of a percent. So if you have 93 octane and add a bottle or two you still have less than 94. There is no substitute for high quality blend race fuels.
post #5 of 12 Old 12-24-2009, 09:57 PM Thread Starter
kelodwro's Avatar
really? I thought that it raised it up tothe number on the bottle... so a 110 bottle goes to 110 octane...
'08 700XX
Power:
K&N air intake
Handling:
Bling:
IMS fuel tank
Gripper seat
kelodwro is offline
post #6 of 12 Old 12-24-2009, 10:18 PM
phucknutz's Avatar
lol, first don't jump out and buy a off the shelf kit. Stay tuned to see what EHS has to offer soon, should blow the Alba out of the water. Second, octane prevents pre-detination, you may not need anything more than pump gas, you can also blend race fuel with pump gas to get the correct mix. Too much octane can hinder performance. The set up you are running should be dyno tested, this will let you know what is nessissary to operate correctly
Big Kidz Racing
Sponsors:
EHS Racing
Barker's Performance
Houser Racing
On The Trail TV
West Virginia ATV Tours
Hinsen Clutch Components
KBC Helmets
Hiper Racing Wheels
Member:
Score International
Best in the Desert
phucknutz is offline
post #7 of 12 Old 12-24-2009, 11:25 PM
I'm not here to back Alba's products as I have my own but there parts or not "off the shelf", Your a bit excited over EHS's product that hasn't even seen the dyno. I understand they are sponsoring you but it's not right to lead others on when the product isn't even fully developed. I've seen Alba's win races and I know personally what mine have done, Neither or generic parts. I'm not doubting EHS capability's but if I were a consumer I would be turned off by all the claims you make and putting down others vendors without anything to back the product or your claims of doing 60+hp, 100+mph and so on.
post #8 of 12 Old 12-25-2009, 01:47 AM
damn... finally you say something sensible... jk
post #9 of 12 Old 12-25-2009, 08:44 AM
I know I've been ranting a bit lately but I do feel strongly on this issue. I know myself and Alba has put allot into making these parts and have each done grenaded motors in the process, From all this I don't expect to put on a podium or congratulated but respect for the effort is appreciated.
Merry Christmas Club700XX !!!!!!!
post #10 of 12 Old 12-25-2009, 09:59 PM
Im gonna jump in here and apologize for nutz, i know he is excited that we are helping him. I defiently do not condone jumping in someones thread and knocking someone elses work.
EHSRACING is offline
