Fmf 4.1 complete with power bomb header - Club700XX - Honda TRX700XX Forum
post #1 of 12 Old 12-22-2009, 09:46 PM Thread Starter
I put the fmf exhaust system on. I was told I didn't need the powercommander because it was fuel injected... Is this true?will it hurt the engine running it without one?
Ironhorse is offline
post #2 of 12 Old 12-22-2009, 09:50 PM
skier207's Avatar
Probably won't hurt your machine, but it won't make much if any more power than stock without a fuel controller. The injection system on this machine does not adapt to mods. It operates on a fixed fuel map.
skier207 is offline
post #3 of 12 Old 12-22-2009, 10:50 PM
With just a slip-on it is not needed, If you have a slip-on and free flow filter it would be best to get one. At anytime you add a header you will need to install a programmer also.
post #4 of 12 Old 12-22-2009, 11:22 PM
With a slip-on the annoying throttle pop (and sequential engine stall) you get when trying to blip the throttle to climb something at or near idle will get worse if you don't add a programmer. Some of you may have noticed this where it backfires through your intake at low rpms due to an already lean factory condition.
post #5 of 12 Old 12-22-2009, 11:47 PM Thread Starter
Thanks..it has been dyin on me alot.seems I have to really give it some gas on take off or ride the clutch to keep it going.it's hard to climb real slow also.witch powercommander should I go with?
post #6 of 12 Old 12-23-2009, 01:26 AM
skier207's Avatar
PCV It's almost the same price as the III, the 5 is smaller and it is more upgradeable.
skier207 is offline
post #7 of 12 Old 12-23-2009, 02:28 AM
VOO-DOO's Avatar
I am also running an FMF exhaust and had similar issues. I ordered the FMF programmer as I got a great deal. The Power Comander will allow for better tuning, however I am not hitting a Dyno. My FMF should be in by this weekend, will update after install.
2008 Black/Charcoal 700xx
Mods:
FMF Stainless Powerbomb header
FMF Titanium Muffler
FMF Programmer
Uni- air filter
10" ITP aluminum wheels with 22" Sand Stars
JT 13T sprocket, with Billet Specialties case saver
and I have a bottle of NOS if needed!
2009 Honda Foreman ES 4x4
Full chasis skid plate, Warn 2500 winch (field tested and approved!), 14" SS wheels wrapped in 26" Baja tires.
I don't have to be the fastest to have fun!
VOO-DOO is offline
post #8 of 12 Old 12-23-2009, 08:17 AM Thread Starter
Cool... Maybe thats what I need. Can't wait to hear how it works out for you!where did you get the 13 tooth sprocket and case saver....I would also like to add that
post #9 of 12 Old 12-23-2009, 08:50 AM
Simplyorange's Avatar
im sure rocky mountain has both, i know the gear is on ebay for around $22 shipped, same as 2008 450r
2007 GSXR 1000 (Orange/Black)
Simplyorange is offline
post #10 of 12 Old 12-23-2009, 09:10 AM
VOO-DOO's Avatar
The sprocket is the same as the 450r as Jarrod said. The case saver and sprocket were both ordered from my local dealer, who then ordered them from rockymountain. I get a pretty good discount so I use my local dealer, even if they bug me some times... The sprocket is a quick effective mod as long as you don't care about the loss of top end.
Mods:
FMF Programmer
Uni- air filter
VOO-DOO is offline
