won't start! - Club700XX - Honda TRX700XX Forum
post #1 of 7 Old 10-08-2015, 07:49 PM Thread Starter
won't start!
Hey guys my 700xx won't crack won't turn over or nuttin. When I turn the key and the engine switch the fuel pump makes a ticking sound an lights barely come on I push the start nuttin. Then sometimes the pump comes on fine and light but when I push the start the starter relay clicks and nuttin happens. I changed the relay and took the programmer off no luck with that so my question is do u think its the fuel pump or something electrical.
Daniel700xx is offline
post #2 of 7 Old 10-09-2015, 07:02 AM
Quoted: 252 Post(s)
How many volts do you have at the battery before turning on? Sounds like weak battery or poor connection somewhere. I hate electrical issues.
post #3 of 7 Old 10-09-2015, 12:00 PM Thread Starter
12.6 then when I push the start button it goes down to like 9 volts.
post #4 of 7 Old 10-09-2015, 07:07 PM
Quoted: 252 Post(s)
Try a jump w/out other vehicle running. After it starts, and you remove cable's recheck volts on running quad. Should be like 14 or so. If that's good change the battery. A fully charged battery on quad should be over 13 volts.
post #5 of 7 Old 10-10-2015, 10:13 AM Thread Starter
Tried it didn't work fuel pump won't prime up it does the same thing just just ticks. I'm thinking I got a ground problem or a short some where
post #6 of 7 Old 10-10-2015, 10:50 AM Thread Starter
Now when I turn the key and engine switch on the volts drop to 8volts I have took all the light off of it unplug the fuel pump and still does it
post #7 of 7 Old 10-10-2015, 12:27 PM Thread Starter
The key watch is bad I just found out but when I jumped it at the plug it's still doing the same thing
