Smoke.. - Club700XX - Honda TRX700XX Forum
post #1 of 2 Old 10-15-2015, 11:19 PM Thread Starter
Quoted: 6 Post(s)
Smoke..
I JUST CHANGED MY PISTON RINGS (THE PISTON LOOKS GREAT SO AS THE Cylinder) PUT ON NEW VALVE SEAL AND IT STILLS SMOKES A BIT ON THE START. the smoke is so little that it stops in less than a half a second. When i leave the trx on neutral and don't accelerate it, it doesn't smoke at all. But once i hop on it and take it for a ride it smokes on revs. i have a full fmf exhaust with racing filter and wiseco power commander. i haven't ridden it as much after doing the valve seal and piston rings change. what could it be? can it be that the rings haven set in yet?
cartuho is offline
post #2 of 2 Old 01-02-2016, 06:47 PM
Robbie Carter's Avatar
Quoted: 9 Post(s)
I'm redoing mine the same way. Is yours still smoking?
Sent from my SM-G900V using Tapatalk
Robbie Carter is offline
