Looking for info. - Club700XX - Honda TRX700XX Forum
post #1 of 10 Old 12-29-2009, 07:47 PM Thread Starter
Looking for info.
I have been looking through my Honda workshop manual and trying to find :
1 -stock compression ratio
2-if I do away with the thermostat housing, where would be the best place for the temp switch
3- Does anybody know where I can get custom cables made .
4-Whacky one but here goes, would a XR650R flywheel and ignition fit !
5- Can't remember , but will let you know.
post #2 of 10 Old 12-30-2009, 08:45 AM
1 10:1
2 Without a thermostat housing you would loose all your coolant. Install the temp switch in nearest puddle.
3 negative
4 The XX has a stronger stator than the XR,You would be going backward
5 Your keys or in the icebox
post #3 of 10 Old 12-30-2009, 09:01 AM
Simplyorange's Avatar
2007 GSXR 1000 (Orange/Black)
Simplyorange is offline
post #4 of 10 Old 12-30-2009, 04:12 PM Thread Starter
The puddle caught me out, So I modified the Pro Armor skidplate and managed to keep 6" ground clearance . Drilled a hole in the skidplate and duct taped the temperature sender in it. Worked fine till I hit 5th gear and part of the puddle disappeared. Had to stop to top up . So I have changed the gearing to 15/36 . Now I can stay in 4th and the puddle stays with me.
Genius !
post #5 of 10 Old 12-30-2009, 06:34 PM
skier207's Avatar
Genius !
What the hell kind of tea have you been drinking?
skier207 is offline
post #6 of 10 Old 12-30-2009, 06:37 PM Thread Starter
The best ! Just trying to find info for the next chapter.
post #7 of 10 Old 12-30-2009, 06:56 PM
skier207's Avatar
Try Motion pro or Terry cable for cables.
http://www.motionpro.com/
http://www.terrycable.com/products/p...aspx?id=MTAwOQ==
skier207 is offline
post #8 of 10 Old 12-30-2009, 07:01 PM Thread Starter
Cheers Ace ! Happy New Year.
post #9 of 10 Old 01-01-2010, 08:00 AM Thread Starter
I remembered, 5 Keihin model number of the fuel pump.
post #10 of 10 Old 04-01-2012, 10:57 AM
Maybe a bit closer to home -
http://www.venhill.co.uk/Home
rappey is offline
