Does this sound right? - Club700XX - Honda TRX700XX Forum
post #1 of 20 Old 01-02-2010, 10:13 AM Thread Starter
LOMO700XX's Avatar
I was just wondering what ur guys' opinion would be on this:
My xx was backfiring/stalling out/running poorly once warmed up, so i took it to the dealer. They said they couldn't find anything wrong with it and just cleaned the spark plug, which they said was blackened. My bike has MAYBE 6 tanks og gas thru it. Probably more like 5. Just seems strange to me that an almost brand new bike is running poorly. Any ideas?
Also, when should i have the valves adjusted and how much is it to have done?
2008 TRX 700XX
1987 ATC 200X
LOMO700XX is offline
post #2 of 20 Old 01-02-2010, 10:33 AM
kelodwro's Avatar
Mine only started that after putting on the full exhaust, without the EFI. After you ride it for a few min, it works fine right?
'08 700XX
Power:
EHS bullet box (Thanks Eric!)
Full HMF exhaust system
K&N air intake
Handling:
Flex bars 14* 31" Quad racer
Bling:
Honda Racing MX front bumper
IMS fuel tank
Red Silicon radiator hoses
Gripper seat
kelodwro is offline
post #3 of 20 Old 01-02-2010, 10:57 AM Thread Starter
LOMO700XX's Avatar
No, it does this when its warmed up like i've been riding for a good 35-40 minutes. Also, it doesn't do it as much/as bad if i run it on reserve. Checked for gas too and it was almost full
2008 TRX 700XX
1987 ATC 200X
post #4 of 20 Old 01-02-2010, 11:20 AM
Funny I had this same problem yesterday on my maiden voyage; first 20 minutes it happened 3 times. Switched it to reserve and it went away; so far. I'm wondering if it will come back when the gas level drops in the tank. I'm thinking the screens inside the tank or a fuel filter is clogged or something. May not be dirt, but some bio-fouling???
Very aggravating any suggestions would be appreciated.
Jeff
2008 Honda TRX 700 - 13T, Uni-Filter, FMF Programmer, PRM Side Bars, Desert Bumper and Skid Plate, CCP Steering Stabilizer, Elka Shocks on all four corners, Kyle8ton Anti-Sway Bar
Currently Own:
2008 KTM 990 ADV
2008 KTM 450 EXC-R
2008 KTM 85XC (Son's Bike)
2010 Polaris 200 (Daughters Bike)
2009 Honda Recon 250
2007 John Deere Gator
2007 Rhino
2007 Honda TRX 500 4x4
2003 Polaris Sportsman 6x6
2002 Sherco 250
jjohn82 is offline
post #5 of 20 Old 01-02-2010, 11:25 AM Thread Starter
LOMO700XX's Avatar
Does it cut out when ur like 1/2 throttle or more, backfires when you let out, then dies?
2008 TRX 700XX
1987 ATC 200X
post #6 of 20 Old 01-02-2010, 11:26 AM
Allot of XX's have the fuel selector installed incorrectly from the dealer/factory. Check to make sure yours installed correctly.
post #7 of 20 Old 01-02-2010, 11:27 AM
Also for the new guys you should check to make sure the two washers/spacers are removed from the front wheels. You can simply look at the rims, If they are there you can see the gap between the rim and hub
post #8 of 20 Old 01-02-2010, 12:14 PM
Hard to say. Yes, I think.
I'm not sure as to why "on" or "reserve" being reversed would affect that at full tank levels, or is the "off" also incorrect?
I'll check that, thank you. Why would they do that?
Jeff
Currently Own:
2008 KTM 990 ADV
2008 KTM 450 EXC-R
2007 Rhino
2002 Sherco 250
jjohn82 is offline
post #9 of 20 Old 01-02-2010, 12:20 PM
https://www.club700xx.com/vb/showthre...ighlight=sorts
post #10 of 20 Old 01-02-2010, 11:11 PM Thread Starter
LOMO700XX's Avatar
how exactly do i go about checking to make sure my fuel selector valve is on correctly?
2008 TRX 700XX
1987 ATC 200X
