Reverse rev limiter - Club700XX - Honda TRX700XX Forum
post #1 of 25 Old 01-02-2010, 05:07 PM Thread Starter
redrider's Avatar
Reverse rev limiter
Finally got my 700 out in the woods for the first time today and man, it was muuuudy!!! Im definitley going to invest in the 13T sproket as stock it def could use a lower first gear for the technical trails.
I found myself using reverse quite a bit as the trails were quite muddy, but reverse was about useless if I wasnt ridding the clutch. It seemed if i tried to put some power to the wheels in reverse the rev limiter kicked in and and made the bike jump all over the place (couldnt find a happy medium). Im sure the 13T sprocket will help but was wondering if anyone else has had this similar problem?
My 700 is stock other than two bros exhaust and juice box (which might have something to do with the choppy throttle in reverse)
redrider is offline
post #2 of 25 Old 01-02-2010, 05:38 PM
It's actually a speed limiter, Just bypass it.
post #3 of 25 Old 01-02-2010, 05:55 PM
700xx crazy's Avatar
How do u do this smooth? I would love to know, it pisses me off(reverse limiter).
Thanks for any info on this!
700XX CRAZY
HMF Ballance slip-on
PCIII w/"BO MAP"
Outerwear Lid Mod (by me)
Trail Tech Riser
Chub Bars
HONDA Bar Pad
RAZR2 Fronts
RAZR Rears
Elephant Ear Hand Guards(LOL)
700xx crazy is offline
post #4 of 25 Old 01-02-2010, 07:00 PM
Unplug it, I think it's the red wire on the right side if you're facing the "driver" side of the engine.
You won't have a reverse light tho....
post #5 of 25 Old 01-02-2010, 08:17 PM
good to know thanks scuzz i wanted to bypass mine today bad. i was up in the snow and let the clutch out and it hit the limiter right away kinda stupid
rodeo is offline
post #6 of 25 Old 01-03-2010, 08:15 AM Thread Starter
redrider's Avatar
sweet, thanks guys!
redrider is offline
post #7 of 25 Old 01-03-2010, 09:07 PM
Thanks Scuzz I'll check mine out to see if i can find the wire. Dont really care if it has a reverse light.
700XX CRAZY
PCIII w/"BO MAP"
Trail Tech Riser
Chub Bars
HONDA Bar Pad
RAZR2 Fronts
RAZR Rears
post #8 of 25 Old 01-13-2010, 11:32 PM
i unplugged the red wire right by the shifter and got nothing are you sure it was the red wire there is another wire there too just dont want to umplug anymore wires right there untill i find out what the right one is thanks
08 700xx red black
pro armour bull horn front bumper
prm standard rear grab bar
prm full skid plate
pro armour fat pegs
dmc after burner full exhaust
power commander pcIII usb
modquad and k&n
pro armour hid light kit
trail tech vapor computer kit
itp sand stars on 12in polished c series
veto.08 is offline
post #9 of 25 Old 01-14-2010, 05:42 AM
I'm not near my quad but I remember it being a wire you had to cut due to there not being a near by plug, Wasn't it yellow scuzz?
post #10 of 25 Old 01-14-2010, 07:20 AM
atleastitsnotaford's Avatar
Just an idea: Cut the wire, then run it to a switch mounted where you can reach while riding that you have to hold to bypass it. kind of like the reverse overide button on the polaris scrambler.
atleastitsnotaford is offline
