Trail Tech Endurance Computer - Club700XX - Honda TRX700XX Forum
post #1 of 85 Old 01-05-2010, 07:58 PM Thread Starter
Send a message via Yahoo to fltcu
does any one have one of this computers?
is it worth the money an how good are they?
fltcu is offline
post #2 of 85 Old 01-05-2010, 08:07 PM
I had a Vapor from Trailtech, they work great as long as you dont use the pressure washer on it! I did and ruined it, TT were great guys and sent me a free replacement no questions asked.
2006 Raptor 700
post #3 of 85 Old 01-05-2010, 08:42 PM
i have one on my xr650r, have had one previously on my ktm 525, and i just bought one for the xx. they are solid, and are a good way to keep tabs on hours/miles/ and engine temp. i need to install mine soon. maybe i'll do a "how to.."
BlackSheep is offline
post #4 of 85 Old 01-05-2010, 09:13 PM
dagirl71's Avatar
How does it track your hours and miles?
Da Girl
dagirl71 is offline
post #5 of 85 Old 01-06-2010, 12:45 AM
Hours it measures when you power on and off your quad so you can track ride times for oil changes, etc. Speed and distance with a sensor installed in one of the front wheels.
2006 Raptor 700
post #6 of 85 Old 01-06-2010, 01:38 PM
warlock28's Avatar
Have mine installed and out using it last weekend. Installed the Vapor with the Trail Tech X-Bars and Clamps. Install was pretty clean and easy. The only problem so far is the Tach is a little jumpy at idle. Working with Trail Tech on that issue. Everything else works great. Highly recommended.
Hope this helps.
2008 TRX700xx X 2
2003 Excursion V10 (Pull Toy)
warlock28 is offline
post #7 of 85 Old 01-06-2010, 02:04 PM
My buddy is on his third one. the first time was the result of a pressure washer and the other two it just died.
post #8 of 85 Old 01-06-2010, 04:17 PM
Hope this helps.
Check with them if your rpm sensor wire has a resistor (I think it was a resistor, not sure), the first raptor vapors had a big issue because they did not have one and the RPMs were all over the place.
2006 Raptor 700
post #9 of 85 Old 01-07-2010, 02:30 PM
warlock28's Avatar
It does not. Ordered the resistor wire and it arrived yesterday. Will be installing this weekend.
2008 TRX700xx X 2
post #10 of 85 Old 01-07-2010, 03:34 PM
Good! Did you actually order it or did they send it free?
2006 Raptor 700
