Drop in cams
I have the ehs big 3 package and am looking for more top end power with close to the same bottom. Im want either the hot cam 2, 3 or webcam 2. Any imput would be great. I would like to keep the bullet box from ehs. if anyone has dyno charts or special maintnence that needs to be performed with one cam and not another that information would be greatly appreciated. Thanks
Sponsored Links | |||
Specifically I would liketo see a chart from the webcam/abla package stage 2 because that is what im really leaning toward.
Hot cams are the only ones that are technically drop in. Most go with the S3 and have been happy from what I've read. A Web cam requires stiffer springs and hardened rockers due to the lobe profile being more aggressive.
Alba doesn't use Web cams anymore in their Stage 2 kit. They use Hot cams as I just inquired about 6 weeks ago before my motor was getting built. Web pulled their offering for awhile in order to fix hard start issues related to the de-compression mechanism. They are now selling them again but it seems Alba hasn't pursued offering them again, for whatever reason.
08' Blackbird XX - IPS tuned/built 53whp woods terror (710cc/10.5:1, Hot Cam S3, Ported Head, Pro design filter, Barker's, PCV, HD Clutch, + much more)
Eric at ehs was sayn that the stage 2 webcam does not require springs or rockers. If the springs and rockers are required I will probably go with the stage 3 hot cam. What kinda bottom end power loss would i be looking at with that cam. I already have the ehs big three.
Sponsored Links | |
Thread Tools | |
Display Modes | |
Posting Rules | |
