Need help with 700xx!! - Club700XX - Honda TRX700XX Forum
 1Likes
post #1 of 19 Old 02-04-2016, 01:04 AM Thread Starter
Quoted: 4 Post(s)
Hey guys I'm new to the forum. Recently bought a 08 700xx. And I love it! Had it for about 7 months now. But these past 2 months it's been acting up on me. The engine is really hard to start. It's spittin and sputtering and the idle is really low. If you give more than half throttle it will bog down and once you let off it'll backfire. You can ease into the gas and it's fine. But if you snap the throttle it'll just bog the entire time. So I changed the fuel filter in it. Helped a little bit. New air filter. New spark plug. Cleaned the throttle body out. It's all stock. I can still drive it. But there's no power and it's bogs down and backfires. I'm the second owner. Could the fuel pump be bad? Or do the valves need adjusting? Help is greatly appreciated!!!
Burtschi5 is offline
post #2 of 19 Old 02-04-2016, 01:05 PM
I'd say it's time to adjust the valves... I doubt the fuel pump is bad because of the backfire.
post #3 of 19 Old 02-04-2016, 08:28 PM
Robbie Carter's Avatar
Quoted: 9 Post(s)
Agree valves. Not a bad job just time consuming
Sent from my SM-G900V using Tapatalk
Robbie Carter is offline
post #4 of 19 Old 02-10-2016, 10:12 PM Thread Starter
Quoted: 4 Post(s)
Okay thanks guys. I don't have a gauge or I would try and do it myself. Dealer said it would take 2 hours. $100 an hour. Might try and find somewhere else to take it.
post #5 of 19 Old 02-11-2016, 06:58 AM
Quoted: 252 Post(s)
Lol @2 hrs! And for $200 you can buy some sweet gauges, lol. And then it would be free next time around. Really it's easy to do. Head to your local auto parts and get a set of angled feeler gauges, probably less than $10. And then hit us back up for info.
blakjak619 likes this.
post #6 of 19 Old 02-11-2016, 08:42 PM Thread Starter
Quoted: 4 Post(s)
Is the vavles underneath the rocker arms? Or they at the bottom of engine? I'm new to all this sorry
post #7 of 19 Old 02-11-2016, 09:19 PM
Quoted: 252 Post(s)
Under the rockers. Download the digital service manual. You basically remove plastics to remove tank, and heat shield. Then there are 2 (intake & exhaust) inspection covers, on top the motor to access the valves.
http://www.mediafire.com/download/lwos5c74tic3ipp/Honda_TRX700xx_Service_Manual%5B1%5D.pd
post #8 of 19 Old 02-11-2016, 09:22 PM
Quoted: 252 Post(s)
Gauges
http://www.autozone.com/clamps-and-m...uge/69339_0_0/
http://www.autozone.com/clamps-and-m...es/466520_0_0/
If you can change the spark plug you can adjust the valves. The plug wire is pretty much impossible for me to remove, unless the tank is pulled.
post #9 of 19 Old 02-12-2016, 06:40 PM Thread Starter
Quoted: 4 Post(s)
Well I adjusted the vavles. And in the process I broke off the boot where the spark plug connects to the actual plug sticking out of the engine. I rescrewed it back on. Hooked it up. Now it wont even crank over. When you try to start it'll just crank real slow then stop. Any ideas?
post #10 of 19 Old 02-12-2016, 07:54 PM
Quoted: 252 Post(s)
1st make sure you have the plug wire fixed correctly. And when you adjusted the valves, did you make sure you were on TDC, and on the compression stroke not the exhaust? Also you did adjust the intake and exhaust valves at there individual specs correctly?
