Purging radiator lines? - Club700XX - Honda TRX700XX Forum
post #1 of 5 Old 03-19-2016, 04:59 PM Thread Starter
Hi guys,
Replaced a few hoses on my radiator and flushed the coolant. What's the process to purge the air out of the system now?
Thanks!
redkaz04 is offline
post #2 of 5 Old 03-21-2016, 01:30 PM
Quoted: 252 Post(s)
Pull the radiator cap, make sure its full as well as the overflow. Start quad with cap off, and let quad run, till water starts to circulate. (Usually around 5-10 mins max) Crack throttle a few times, top off as needed then replace cap.
When you flushed did you have the t-stat housing drain open?
M_Quick is online now
post #3 of 5 Old 03-21-2016, 11:54 PM Thread Starter
I don't think so... Where is that located?
redkaz04 is offline
post #4 of 5 Old 03-21-2016, 11:59 PM
Quoted: 252 Post(s)
It's the front lower bolt on the thermostat housing/cover. Do you have the service manual?
post #5 of 5 Old 03-22-2016, 08:35 PM Thread Starter
I don't. I need to download it I guess huh....
redkaz04 is offline
