Running just an FMF programmer - Club700XX - Honda TRX700XX Forum
post #1 of 12 Old 01-21-2010, 12:59 AM Thread Starter
slimedog's Avatar
Has anybody ran just an FMF programmer? I was thinking of starting with one just to get the stock mixture better and see how it does. Especially here in Calif, things seems to run so lean. Also in reading some people are saying to read the O2 sensor voltage to get a correct mixture. What reading should i see and would it cross count similar to cars? I don't even have a manual yet and would get one before, so just throwing out ideas., Thanks, lew, slimedog
slimedog is offline
post #2 of 12 Old 01-21-2010, 09:31 AM
The XX doesn't have an O2 sensor to get a reading from. There is nothing wrong with running just a programmer, It will help even without other upgrades. If you buy a dobek style controller you should consider the Alba or EHS. I had the FMF and wasn't happy with it.
post #3 of 12 Old 01-21-2010, 04:48 PM
logme13's Avatar
How do you like your PCV w/autotune smooth
logme13 is offline
post #4 of 12 Old 01-21-2010, 08:03 PM
warlock28's Avatar
Originally Posted by smo0oth1 View Post
The XX doesn't ..... If you buy a dobek style controller you should consider the Alba or EHS. I had the FMF and wasn't happy with it.
What did you not like about the FMF? I have one and like it, but have nothing to compare it to.
2008 TRX700xx X 2
2003 Excursion V10 (Pull Toy)
warlock28 is offline
post #5 of 12 Old 01-21-2010, 08:55 PM
SamHarrison's Avatar
I thought all the dobek controllers were the same. My FMF has worked flawless.
FMF EFI Power Programmer
Modquad Air Flow System with K&N
Primary Drive Front Sprocket-13 Tooth
Pro Armor Frame Armor
Pro Armor Swing Arm Armor
Rear tires-Maxxis Razr
SamHarrison is offline
post #6 of 12 Old 01-21-2010, 09:23 PM
vfm2010's Avatar
I'm using just the PC5(I'm sure anything would be an improvement) right now and it's helped alot. No more popping and stalling, and it feels much stronger under acceleration. I will eventually get a full exhaust and the autotune. The only other "performance" mod I have is the 13 tooth sprocket.
88 LT500R QUADZILLA
06 DVX400 (Son's)
06 TRX250EX (Wife's)
vfm2010 is offline
post #7 of 12 Old 01-21-2010, 10:46 PM
I'm surprised they run so lean from the factory. I'll start mine and it will shut off, I'll have to restart it. I can't lug the engine nearly as much as my 400ex.
post #8 of 12 Old 01-21-2010, 11:07 PM
mrtheandrew's Avatar
there is a group buy for ehs controllers right now if youre looking to get a good deal on one...
https://www.club700xx.com/vb/showthread.php?t=2068
mrtheandrew is offline
post #9 of 12 Old 01-21-2010, 11:08 PM
What will the price be?
post #10 of 12 Old 01-21-2010, 11:09 PM
vfm2010's Avatar
Have you tried the 13 tooth sprocket yet?
88 LT500R QUADZILLA
06 DVX400 (Son's)
vfm2010 is offline
