Help please! - Club700XX - Honda TRX700XX Forum
post #1 of 5 Old 04-15-2016, 10:36 AM Thread Starter
Unhappy Help please!
Hello all, I am new to the club, I have 2009 trx 700, I let it sit since August 2014, gas was bad, drained tank, battery was dead. I tried pop starting it, it would run for a minute then die out, so my questions are, does the battery need to be at a certain percentage to have everything working properly? And should I change plug,injector and is there a fuel filter? This is my first fuel injected quad, so need lots of help,
Thank you Eddie
fasteddie1077 is offline
post #2 of 5 Old 04-15-2016, 12:11 PM
It could be that the battery is so dead that the quad cant keep itself going?
As for fuel, i aquired a cbr600 that had been sat outside in london after a crash with just a cover over it, took it home, changed the oil, fitted a new battery and within 30 secs it was purring on 3 year old fuel !
I,m sure if you hang in there for a while someone with lots more technical knowledge will answer all your questions !
rappey is offline
post #3 of 5 Old 04-15-2016, 01:05 PM Thread Starter
Thank you, it was trying to stay running with the old gas, but I figured draining it would be the fastest and cheapest way to try, until I can get a battery lol
post #4 of 5 Old 04-16-2016, 08:10 AM
Quoted: 144 Post(s)
yeah battery's, I just ordered this one STZ14S Powersports Battery - Replaces: YTZ14S,*GTZ14S,*UTZ14S,*PTZ14S,*FAYTZ14S
cataway is offline
post #5 of 5 Old 04-16-2016, 12:02 PM
Quoted: 144 Post(s)
BTW, the STZ14S is a perfect fit
cataway is offline
