electrical starter HELP!!! - Club700XX - Honda TRX700XX Forum
post #1 of 5 Old 01-23-2010, 07:58 PM Thread Starter
ok i was out playin today and was running through some water no deaper than the nerfs and now my quad starts every time you turn the key meaning you dont have to push the start button. or if the key is on and you turn the kill swithch on it turns over and the starter keeps turning over as it is running.
post #2 of 5 Old 01-23-2010, 08:15 PM
700woodsrider's Avatar
Check for a stuck or shorted starter button or stuck / shorted starter relay. The starter relay is located in a rubber mount next to the battery.
2008 TRX700XX - Sold
2005 Raptor 660R - Rebuild Project "The Phoenix"
700woodsrider is offline
post #3 of 5 Old 01-23-2010, 08:16 PM
You should start by checking the starter switch
post #4 of 5 Old 01-23-2010, 11:13 PM Thread Starter
ok all fixed had to use heat gun on switch got waterin there some how.
post #5 of 5 Old 01-24-2010, 08:06 AM
it's the starter button....this happen to my recon a few times
