700xx wont start - Club700XX - Honda TRX700XX Forum
post #1 of 8 Old 04-30-2016, 07:06 PM Thread Starter
700xx wont start
i was riding though an open field in 4th gear and when i shifted to 5th my motor started making a knocking sound so i downshifted and it almost immediately died on me. after that it wont start and the only thing it will do is backfire. i thought my timing chain might have broke and that was what i was hearing in slap around my motor but when i pulled the valve cover and spun the motor my chain looked fine and was very tight. ever since then it wont run and ive tried everything i can think of. i adjusted the timing to where i am quite sure the timing marks are dead on and it made no difference. i changed my plug and it has a strong spark. i checked my fuel pump and injector and they seem to be working fine. i cant seem to figure out why it wont run and was hoping someone could point me in the right direction. the weather wear i live is just starting to get nicer and i would love to be able to ride, thanks for any advice.
6.7superduty is offline
post #2 of 8 Old 04-30-2016, 07:20 PM
Sounds like you're not getting compression. Could be valves, piston rings, or piston.
Sent from my iPhone using Tapatalk
Moroz998 is offline
post #3 of 8 Old 04-30-2016, 11:28 PM
Quoted: 144 Post(s)
a knocking sound is never a good thing
cataway is offline
post #4 of 8 Old 05-01-2016, 11:23 AM
You should do a "leak down test", that should give you a better idea of where your problem is.
post #5 of 8 Old 05-01-2016, 11:39 AM
Quoted: 144 Post(s)
a main bearing came apart on me once ..........that will make a knocking noise
cataway is offline
post #6 of 8 Old 05-02-2016, 07:36 AM Thread Starter
Thanks for all the input I bought a compression tester and it only had like 10 psi turns out after I pulled the cylinder my piston is scored up as well as my cylinder wall. The rebuild kit is in the mail. Thanks for the help
post #7 of 8 Old 05-02-2016, 11:04 AM
How does the rebuild kit fix the cylinder walls? Is it sleeved cylinder?
Moroz998 is offline
post #8 of 8 Old 05-05-2016, 01:09 PM
Most rebuild kits have a "core" type arrangement... you send them your old cylinder to be rebuilt and sent back... OR the kit comes with a rebuilt cylinder and you send your cylinder back to them to be rebuilt for the next guy. No sleeves and not coated either. Alba offers a rebuild kit that will take you from 686cc to 715cc
