Custom Head Pipe - Club700XX - Honda TRX700XX Forum
post #1 of 7 Old 01-25-2010, 05:33 PM Thread Starter
LOMO700XX's Avatar
Custom Head Pipe
If I bought the Yoshimura slip-on, could I have someone weld up a custom head pipe to go with it? I'm asking because I like the yoshi pipe but might want a full system down the road....
Thanks,
Drew
2008 TRX 700XX
1987 ATC 200X
LOMO700XX is offline
post #2 of 7 Old 01-25-2010, 06:33 PM
What size is the Yoshi mid pipe? If it's the same size as the stock mid pipe then you will have to use the stock header. This is a downfall to slip ons that do not offer headers with it.
post #3 of 7 Old 01-25-2010, 06:47 PM
phucknutz's Avatar
I don't believe Yoshi even builds a header, you will have to go a different direction when you are ready.
Big Kidz Racing
Sponsors:
EHS Racing
Barker's Performance
Houser Racing
On The Trail TV
West Virginia ATV Tours
Hinsen Clutch Components
KBC Helmets
Hiper Racing Wheels
Member:
Score International
Best in the Desert
phucknutz is offline
post #4 of 7 Old 01-25-2010, 06:56 PM Thread Starter
LOMO700XX's Avatar
Yoshi doesn't make a header, thats why i was gonna have this guy i know who does exhausts fab up a header for it.
2008 TRX 700XX
1987 ATC 200X
post #5 of 7 Old 01-25-2010, 07:02 PM
The point is though, If the Yoshi mid pipe is the same 1 3/8" as the stock mid pipe then you would have to use the stock header. You could have someone build you a header but it would still be the same size as the stock and not make any more power. Your best bet is to look at the other manufacturer's who offer headers and buy there slip on. Compromise your taste of looks for the additional power your after.
post #6 of 7 Old 01-25-2010, 07:07 PM Thread Starter
LOMO700XX's Avatar
Okay,thanks for the info. Did DASA ever make that exhaust available?
2008 TRX 700XX
1987 ATC 200X
post #7 of 7 Old 01-26-2010, 09:47 PM
talk with your exhaust guy you just may have to do a little fab work on the yoshi as well. if you did build a header and keep the muffler the same you would have to neck it down to connect and might not get the air flow you want
