were'd my oil go ??????? - Club700XX - Honda TRX700XX Forum
post #1 of 6 Old 06-15-2016, 02:05 PM Thread Starter
Quoted: 144 Post(s)
I'm abit confused. I know that I put oil in after the oil change ,went riding and came back with little or on oil in it. its a new top end build and I have yet to find a leek and there's no blue fog .
its got me baffled .
were do I want to send my rocker arms to get them hardened ?
cataway is offline
post #2 of 6 Old 06-15-2016, 05:27 PM
Idk about your oil, this quad is hard to get accurate read if you ask me. To be safe drain it and add new. You will be able to tell from how much drains out, if you have a issue.
On the rockers, I believe Alba racing still does them, but webcamshafts.com for sure. Ehs racing may also do them but idk?
post #3 of 6 Old 06-15-2016, 06:52 PM
nacho's Avatar
Quoted: 11 Post(s)
Agreed. It is ridiculous. I have gotten some crazy readings in the past. The manual states to run the engine for 5 minutes then check upon shutting it off. I do this every time now and my readings are consistent.
TRX700XX
KFX700
TRX250EX
85 ATC250R
nacho is offline
post #4 of 6 Old 06-15-2016, 09:05 PM Thread Starter
Quoted: 144 Post(s)
my oil seams to be disappearing
cataway is offline
post #5 of 6 Old 06-16-2016, 05:47 AM
Did you drain it to check how much was in bike? If disappearing, it has to be either leaking or smoking it. Either of which I'm sure you'd notice.
post #6 of 6 Old 06-23-2016, 11:07 AM
After long or hard rides the oil will push out the crankcase breather... I constantly check my oil and it can be difficult to get an accurate reading as discussed... I also do what Nacho said and you will find you readings should start to be more consistent...
FYI: Also when doing an oil change my bike always takes more oil then what the manual says...
RacingRealtor is offline
