751 compression rate - Club700XX - Honda TRX700XX Forum
post #1 of 2 Old 06-26-2016, 08:52 AM Thread Starter
Quoted: 142 Post(s)
does it change if a +3 crank is installed ?
cataway is offline
post #2 of 2 Old 06-27-2016, 05:41 PM
09RappySE's Avatar
Quoted: 16 Post(s)
Yes, adding a stroker crank will raise compression. On a raptor it adds a half point, It should be the same on the XX.
734 09 Raptor
Tuned by EHS Racing 78hp 55Tq
09RappySE is offline
