lower unit back in the frame - Club700XX - Honda TRX700XX Forum
post #1 of 4 Old 07-02-2016, 06:46 PM Thread Starter
Quoted: 141 Post(s)
which BTW was made a lot easier with the use of a over head winch line .
after the little problem with the lack of oil and the fact that I had accidentally dropped a screw into the lower , and BTW could not retrieve it .I decided to remove the engine ........and if I have to remove the lower unit to fine a screw , I may as well replace the crank with a stoker crank .
BTW that lower part is heavy .
cataway is offline
post #2 of 4 Old 07-06-2016, 01:35 AM
blakjak619's Avatar
Quoted: 34 Post(s)
What type of crank? I've run a Hot Rods stroker crank in my Raptor without issue but heard some pretty bad things bout em..
Sent from my SM-G930P using Tapatalk
blakjak619 is offline
post #3 of 4 Old 07-06-2016, 04:28 AM Thread Starter
Quoted: 141 Post(s)
its a Hot Rods stroker crank . I also have a Hot Rods stroker crank in my ltz400 , the only problem I have had is with the Hot Rods bearings .
cataway is offline
post #4 of 4 Old 07-06-2016, 02:53 PM
blakjak619's Avatar
Quoted: 34 Post(s)
Good luck migo! If you can post some pics when you tear it apart
