rolles over hard - Club700XX - Honda TRX700XX Forum
post #1 of 10 Old 07-23-2016, 07:33 PM Thread Starter
Quoted: 141 Post(s)
rolles over hard
put new hot cam in now it acts as if the decompressor in not working .
very little is said in the shop manual about the decompressor. what could be the problem ?
cataway is offline
post #2 of 10 Old 07-23-2016, 09:06 PM
Quoted: 252 Post(s)
Hotcam stage 3...
M_Quick is online now
post #3 of 10 Old 07-23-2016, 09:56 PM Thread Starter
Quoted: 141 Post(s)
u saying I'm screwed
cataway is offline
post #4 of 10 Old 07-23-2016, 10:29 PM
Quoted: 252 Post(s)
No but it's a wide spread problem it seams with the stage3. While some say they don't have any issues. I think someone posted up awhile back, mentioning to put quad in gear, and rock it back and forth. Then pull in clutch and hit starter.
post #5 of 10 Old 07-24-2016, 08:47 AM Thread Starter
Quoted: 141 Post(s)
i'm thinking the lobe of the cam is greater than the lobe of the decompressor. I will be making some phone calls . maybe even Ron knows the best fix
cataway is offline
post #6 of 10 Old 07-24-2016, 09:46 AM
Quoted: 252 Post(s)
I killed 2 lithium batteries on mine. Some say higher cranking amp batteries help. But I was told by a battery guy that CCA are just that. To help in cold weather only.
post #7 of 10 Old 07-24-2016, 03:05 PM Thread Starter
Quoted: 141 Post(s)
I can understand that it could kill a starter but a battery ?
cataway is offline
post #8 of 10 Old 07-25-2016, 06:12 PM Thread Starter
Quoted: 141 Post(s)
made a call to hotcams the response was that they had never heard of any problems with the Stage 3
cataway is offline
post #9 of 10 Old 07-26-2016, 07:47 PM Thread Starter
Quoted: 141 Post(s)
here is the email I was sent ; Thank you for the input! We haven’t heard of any issues here that I recall. What exactly is or is not happening? Has anyone come up with a resolution for the problem that you have seen on the forums? I would like as much detail as you can give me so that we can investigate and if necessary, correct the problem on our end.
Thank you in advance!
OMG do they expect me to find and fix the problem so they don't have to .
cataway is offline
post #10 of 10 Old 07-29-2016, 01:32 PM Thread Starter
Quoted: 141 Post(s)
found the answer to the problem .
when I replaced the cam there is a need to adjust the valve lash , da . the decompressor on the Honda forces the right side exhaust valve open just enough to reduce the compression pressure in the cylinder . if the valve lash is greater than it should be then the decompressor lobe can not touch to open the valve . I had set the lash to the recommended spec's ,.008 + -1 .001 ,hence my confusion as to why there was a problem. when I had gotten the valve lash down to .005 (.127mm) the problem went away.
cataway is offline
