HELP Fuel pump, filter, injector - Club700XX - Honda TRX700XX Forum
 1Likes
  • 1 Post By 007HONDA700
post #1 of 9 Old 08-06-2016, 05:18 PM Thread Starter
I am working on my 700 that has been in storage a few years now. Replaced pump with new side design fuel filter. The pump does start up when I turn on. I have fuel from injector but it doesn't seem enough to start her up. When I bypass injector and place fuel in manually she will burn that fuel and then stop. Can anyone help please? I'm at a loss?
Thanks!
James
Tunnel_Vision likes this.
007HONDA700 is offline
post #2 of 9 Old 08-06-2016, 06:29 PM
Quoted: 141 Post(s)
ok.................what is a side design fuel filter ?
cataway is offline
post #3 of 9 Old 08-06-2016, 09:17 PM Thread Starter
Honda changed the design of the fuel pump so that the filter now sits on the side of the pump instead of the bottom. It's suppose to work better
post #4 of 9 Old 08-06-2016, 11:49 PM
Quoted: 252 Post(s)
Where did you buy this new fuel pump? And you say Honda changed the design? None of the parts houses i buy from show a different pump. Part# 16700-HP5-602 Yours may not have the right pressure that the oem had, and the trx700xx needs.
post #5 of 9 Old 08-07-2016, 01:54 PM Thread Starter
16706-HN8-305. This is the part number I replaced it with. Today I can reinstall the old one to see if that works.
post #6 of 9 Old 08-08-2016, 05:00 PM Thread Starter
So. I have fuel feeding from the injector and it still won't start. Could I not be getting enough pressure from the pump? And how would I be able to tell?
James
post #7 of 9 Old 08-08-2016, 07:20 PM
Quoted: 252 Post(s)
Should be a pretty good spray coming out. I'd pull spark plug, then disconnect injector, put fuel line in a bottle. Turn on hit starter, and fuel should flow out pretty damn fast.
So I'm clear, you put the original pump back on right? If so why did you order the other pump to begin with. My guess quad wasn't starting...
post #8 of 9 Old 08-09-2016, 08:50 AM
Quoted: 252 Post(s)
Do you have a copy of the service manual?
post #9 of 9 Old 08-14-2016, 06:28 PM
Quoted: 5 Post(s)
I am also having trouble with my fuel system between the pump assembly and the injector. I was looking at buying this pump, will it work?
Kemso High Performance Fuel Pump for Honda TRX700XX A 3A 2008 2009 | eBay
Jgspahn is offline
