700xx Hard to start after Big Bore kit - Club700XX - Honda TRX700XX Forum
post #1 of 27 Old 08-16-2016, 09:42 PM Thread Starter
Quoted: 5 Post(s)
Just put a cylinder works big bore kit on the Honda. Now when it's been sitting I usually cranks up fine and easy. After you ride it for a minute tho it seems really hard to start like the battery or the starter doesn't have the power to turn the motor over. The battery is brand new. Any suggestions???
Jgspahn is offline
post #2 of 27 Old 08-17-2016, 05:45 AM
Quoted: 141 Post(s)
you may have to set the right side exhaust valve a bit tighter to get the decompressor to work properly .
the book does say .008 and that's fine...... when it was new . try .006
cataway is offline
post #3 of 27 Old 08-17-2016, 08:39 AM Thread Starter
Quoted: 5 Post(s)
If I'm sitting on the bike, the right side exhaust valve would be the front right one correct?
Jgspahn is offline
post #4 of 27 Old 08-17-2016, 01:32 PM
i fitted the same, plus a stroker crank, and starting is exactly the same as it was before...
i know this is not much help to you but at least you know it should start normally
rappey is offline
post #5 of 27 Old 08-17-2016, 06:09 PM
Quoted: 141 Post(s)
what cam are you's using
cataway is offline
post #6 of 27 Old 08-17-2016, 07:46 PM
Quoted: 252 Post(s)
I'm thinking a smaller valve lash (may) not let enough oil flow? Might not be a issue with hardened rockers, but idk?
post #7 of 27 Old 08-17-2016, 08:40 PM
Quoted: 141 Post(s)
oil flow?
cataway is offline
post #8 of 27 Old 08-17-2016, 09:00 PM
Quoted: 252 Post(s)
Originally Posted by cataway View Post
oil flow?
Yeah you know the stuff that lubricants the internal parts of the motor. Maybe oil flow isn't the correct term, but you need oil in between the rockers and valves.
post #9 of 27 Old 08-17-2016, 09:04 PM
Quoted: 141 Post(s)
the decompressor on the XX cam only works if the valve lash is set with just enough space to force the right side valve to open .
to much lash ,then the valve is not bumped .
next time you remove the cam look at the decompressor . you will likely see a shiny spot . the more that spots hits ,the more it wears ,the more it wears , then less valve lash is needed to them bump the valve open .
sad that we can not get that part .
cataway is offline
post #10 of 27 Old 08-17-2016, 09:20 PM Thread Starter
Quoted: 5 Post(s)
So tighter clearance on the exhaust valve?
Jgspahn is offline
