spark plug boot - Club700XX - Honda TRX700XX Forum
post #1 of 6 Old 02-05-2010, 10:46 PM Thread Starter
spark plug boot
Going to set my valves and pulled the spark plug boot apart. Anyone else done this and do you have to replace the coil to fix?
iowa fan is offline
post #2 of 6 Old 02-05-2010, 11:02 PM
blkcruzer's Avatar
The yellow boot just turns off counterclockwise, and you just thread the new one on. I tore mine pulling the plug wire trying to install the sensor wire for my TT Vapor. Definately don't need to replace the coil.
Jason
2008 TRX700XX Black/Red
Mods:
Trail Tech Vapor with Riser
ODI Rogue Grips
Pro Armour FatPeg Nerfs
PRM rear grab bar
PRM .190 full skid plate
Pro Design K&N Intake
EHS Fuel programmer
22" Razr2 fronts
22" Razr rears
DS450 front reservoir shocks
L8ton 11/16 Sway bar
blkcruzer is offline
post #3 of 6 Old 02-06-2010, 09:08 AM
whats the best way to get the spark plug boot off without tearing it i didnt know it was that tough to get off which i never tried yet.
post #4 of 6 Old 02-06-2010, 10:48 AM
blkcruzer's Avatar
ya just have to weasel your hand in and grab it, I tried with a needle nose, and that tore about half of the rubber off of it, so it is hands only for me now.
Mods:
ODI Rogue Grips
PRM rear grab bar
EHS Fuel programmer
22" Razr2 fronts
22" Razr rears
post #5 of 6 Old 02-06-2010, 04:37 PM
b.courtney_700xx's Avatar
lol blkcruzer i did the same thing to mine man that sucks i was kinda pissed at myself
b.courtney_700xx is offline
post #6 of 6 Old 02-06-2010, 08:29 PM
I tore mine too. I have yes to replace mine and actually used high-heat RTV to put it back together. I (as of yet) have had an issue with water and it shorting out and I've been up to the intake with water on it.
It's the same part number as a 650r fyi...
