Running rich - Club700XX - Honda TRX700XX Forum
 2Likes
post #1 of 12 Old 11-11-2016, 01:26 PM Thread Starter
blakjak619's Avatar
Quoted: 34 Post(s)
Running rich
Alright after many dyno runs my xx is still running a bit rich. Have ruled out bad gas along with controller and ignition settings so looking for some ideas on what the issue could be. Dayton Lock recommended checking the coolant sensor and map sensor just looking for ideas before spending more money
Sent from my SM-G930P using Tapatalk
blakjak619 is offline
post #2 of 12 Old 11-11-2016, 01:29 PM
Quoted: 253 Post(s)
So you can't just take away fuel with your controller? And keep in mind a bit rich is better than lean.
post #3 of 12 Old 11-11-2016, 01:39 PM Thread Starter
blakjak619's Avatar
Quoted: 34 Post(s)
The build has a known map and dyno numbers on point it seems. Even if adjusted manually something is off I suppose
post #4 of 12 Old 11-14-2016, 03:40 AM
Quoted: 4 Post(s)
Possible causes may be a dirty air filter or a damaged or improperly set carburetor float.
blakjak619 likes this.
nighttones is offline
post #5 of 12 Old 11-14-2016, 06:48 AM
Quoted: 253 Post(s)
headscratch
lmao yeah check the float...
post #6 of 12 Old 12-07-2016, 09:31 AM
Quoted: 4 Post(s)
You probably need to also clean the carb.
post #7 of 12 Old 12-07-2016, 10:52 AM Thread Starter
blakjak619's Avatar
Quoted: 34 Post(s)
Just an fyi the 700xx is fuel injected...
post #8 of 12 Old 12-07-2016, 02:33 PM
Quoted: 253 Post(s)
So did you you check the float, also might wanna check the main & pilot jets...
post #9 of 12 Old 12-07-2016, 02:37 PM Thread Starter
blakjak619's Avatar
Quoted: 34 Post(s)
Haha I haven't checked anything for a few weeks but have all the sensors on order and may send my TB out for a +2
post #10 of 12 Old 12-07-2016, 03:08 PM Thread Starter
blakjak619's Avatar
Quoted: 34 Post(s)
Off topic but I raced a 450 this past weekend in Baja. My xx surprisingly corners better than this bike but it was a blast in thr whoops compared to the heavy xx..
