Rev Box - Club700XX - Honda TRX700XX Forum
post #1 of 22 Old 02-09-2010, 12:05 PM Thread Starter
Rev Box
Anyone making a rev box that will let this thing wind up a little more?
latervikes is offline
post #2 of 22 Old 02-09-2010, 01:37 PM
I'd be interested in an answer as well. I do remember a post where it was mentioned something about a rev limiter in 5th gear taking timing away and a fix to that, but the fix was not disclosed... or something of that nature anyway.
How about it guys... anyone know the answer? Give us DETAILS if you do.
post #3 of 22 Old 02-09-2010, 02:02 PM
A rev box allows the rpm to go higher and usually has a different timing curve. There's none officially released as of yet.
post #4 of 22 Old 02-09-2010, 03:19 PM
Just a question... Why would you want to rev it higher when the power starts dropping off well before the stock limiter?
2007 Yamaha R1 Charcoal/Black
THREESVTS is offline
post #5 of 22 Old 02-09-2010, 03:32 PM
These are usually used on built motors. The ignition curve is changed so that it benefits the higher rpms characteristics of cams increasing rpm potential. You can see in my dyno below how the power curve is pretty straight across, If I were to add a Rev box it would make more power and increase with rpm
(Disregard the Blue, it was a pull through the gears. The red was a fourth gear pull)
post #6 of 22 Old 02-09-2010, 05:02 PM
No I totally understand the benefit of using one on a built engine. I've used them on built Mustang's, BMW's, and a few race bikes. But most people don't build their engines and put it on the as delivered from Honda engine. Is there a benefit (doubtful) on a stock engine or is it just for bragging purposes?
post #7 of 22 Old 02-09-2010, 05:52 PM
If the ignition isn't set to radical you would benefit a little from it.
post #8 of 22 Old 02-13-2010, 12:49 AM Thread Starter
I guess I should have stated I plan on dropping some $$ on the big 3 and then go from there. I am just assuming once I get it opened up a little it will start bumping the rev limiter. I could be wrong....was just curious.
post #9 of 22 Old 02-16-2010, 03:23 PM
any chance a 450 and 700 cdi's are the same???
post #10 of 22 Old 02-16-2010, 03:40 PM
The plugs or not the same on the 450
