Cleaning your air filter? - Club700XX - Honda TRX700XX Forum
post #1 of 20 Old 02-17-2010, 12:34 PM Thread Starter
I was wondering what would be best for cleaning my air filter. I was thinking about using dish soap and then buying some filter oil to recharge it. Thoughts? Any other ideas?
post #2 of 20 Old 02-17-2010, 12:40 PM
If you use dish soap, I'd use something like Dawn. I just use Simple Green and K&N oil.
Just make sure the filter is ALL the way dry before you oil it and then don't over oil it.
post #3 of 20 Old 02-17-2010, 12:41 PM Thread Starter
Ok, cool. thanks
post #4 of 20 Old 02-17-2010, 01:08 PM
Also, don't force dry it. Let it dry naturally, meaning don't use air. If you have a boot dryer (Like Peets), you could slip it over and let it dry quicker, but the best thing is just to air dry it in a warm room. You could use an oil or something, such as a parts washer, and also, if you get the K&N recharge kit, I am pretty sure it comes with a solvent for cleaning. I got mine right at autozone for my car and truck.
post #5 of 20 Old 02-17-2010, 03:49 PM
I does indeed. However, the Simple Green is a cheaper way to go and the element is different in a K&N filter and our foam filter... using a solvent may or may not be good for a foam filter. However, the oil would be the same. One of my friends just uses tranny fluid or brake fluid. I decided not to go that way... decided to stay with actual filter oil.
post #6 of 20 Old 02-17-2010, 06:05 PM
If your talking factory installed or the one the dealer set it up with, i believe that is covered with petroleum based oil and will need to be cleaned with some sort of solvent or kerosene or gas. I really doubt dish soap will work.
My bad. Guess you were talking K&N.
Mark97XP is offline
post #7 of 20 Old 02-17-2010, 06:16 PM
I recommend a Twin Air filter cleaning kit for foam filters and K&N filter cleaner for a K&N filter.
post #8 of 20 Old 02-17-2010, 07:57 PM
I've never heard to not force dry one, Whats the cons of it?
post #9 of 20 Old 02-17-2010, 08:46 PM
kennyg700xx's Avatar
I was taught by my Dad,(an old snowmobile rider) to wash filters in dish soap,lightly, then let air dry, then spray externally with a light coat of wd40. Has worked great for me.
2008 honda700xx
2007 honda250ex(wifes)
2009 FORD F150 supercab
kennyg700xx is offline
post #10 of 20 Old 02-17-2010, 10:25 PM
People try differant things. I run differant to you guys in the US because it works for me.
If it works for you then stick with it.
