power commander maps - Club700XX - Honda TRX700XX Forum
post #1 of 5 Old 02-22-2010, 01:43 PM Thread Starter
hello guys im looking to get a power commander v. but have a question about maps. can you use power commander 3 maps in the power commabder v.
second question
if you are using auto tune (witch i will not) can the map be removed from there power commander and used in my power commander v or is the map contantly changing ?
corsasri is offline
post #2 of 5 Old 02-22-2010, 04:32 PM
No, A PCIII map will not work in a PCV.
Yes, The autotune runs "on" the base map, or works around it to say. So the base map in a PCV never changes and can be used on another.
post #3 of 5 Old 02-24-2010, 04:11 PM
ein
ein's Avatar
Quoted: 4 Post(s)
Which is better?? pc3 or pc5??? if money was not an issue which would you prefer? which has more maps? Which is easier to use?? and lastly.... where can you buy them?? (right now, i'm stock, but i see the big 3 in my near future)
ein is offline
post #4 of 5 Old 02-24-2010, 05:08 PM
700xx crazy's Avatar
PC5, u base map it and the autotune does the rest.
700XX CRAZY
HMF Ballance slip-on
PCIII w/"BO MAP"
Outerwear Lid Mod (by me)
Trail Tech Riser
Chub Bars
HONDA Bar Pad
RAZR2 Fronts
RAZR Rears
Elephant Ear Hand Guards(LOL)
700xx crazy is offline
post #5 of 5 Old 02-24-2010, 06:47 PM
That's if you have the O2 Sensor install to make the Auto Tune to work.
