power commander v location - Club700XX - Honda TRX700XX Forum
post #1 of 26 Old 02-25-2010, 06:03 AM Thread Starter
hello if you have a power commander fitted to your 700xx, know the instructions say it just lays under the seat. but as anyone managed to locate it in the air box housing ? as i am just about to order one and would like to put it in there to protect it from water ect.
cheers gary
corsasri is offline
post #2 of 26 Old 02-25-2010, 07:13 AM
Yes, many have posted of putting the PC in the airbox.
post #3 of 26 Old 02-25-2010, 07:28 AM Thread Starter
well after that reply i have placed my order for one.
would be good to see a photo of it located in the air box just so i know where to fix it.
corsasri is offline
post #4 of 26 Old 02-25-2010, 07:46 AM
There are quite a few posts with pics already, I've posted some myself. I'd SEARCH and give you some links but I'm posting on my phone.
post #5 of 26 Old 02-25-2010, 08:06 AM
phucknutz's Avatar
water will not hurt the controler, I have mine in a billet alluminum protector by EHS Racing. They are availiable at www.ehsracing.com
Big Kidz Racing
Sponsors:
EHS Racing
Barker's Performance
Houser Racing
On The Trail TV
West Virginia ATV Tours
Hinsen Clutch Components
KBC Helmets
Hiper Racing Wheels
Member:
Score International
Best in the Desert
phucknutz is offline
post #6 of 26 Old 02-25-2010, 08:10 AM
phucknutz's Avatar
it can also be mounted to the handle bars if you wanted to have full access for on the fly adjustments
Big Kidz Racing
Sponsors:
EHS Racing
Houser Racing
On The Trail TV
KBC Helmets
Hiper Racing Wheels
Member:
Score International
Best in the Desert
post #7 of 26 Old 02-25-2010, 08:53 AM
Where have you read the PC is water proof? The only reason to mount it on the bars would be to try and look cool while fubaring your map on the fly. I wouldn't recommend for anyone to try and tune a PC on the fly much less without a dyno
post #8 of 26 Old 02-25-2010, 01:36 PM
I wouldn't install it on the handlebars, take a chance getting in a wreck but don't see why we can not adjusted on the fly, I used to replace jets on the trail depending on the altitude. Understand that I wouldn't try to adjust it while riding but you could stop and adjust then take off.
post #9 of 26 Old 03-03-2010, 12:34 PM Thread Starter
as anyone got a power commander v. as i got mine today and the cables are so dam short. from the main box to the injector plugs 6 inch
from main box to earth 5 inch
throttle wire 4 inch.
im never going to get this anyway neer the air box to locate it in there
mods to my trx700xx
corsasri is offline
post #10 of 26 Old 03-03-2010, 03:24 PM
vfm2010's Avatar
Yep, they are short. I just have mine resting under the seat, but with Spring around the corner and all the mud I will be looking to find a small protective box for it.
88 LT500R QUADZILLA
06 DVX400 (Son's)
06 TRX250EX (Wife's)
vfm2010 is offline
