chain lube - Club700XX - Honda TRX700XX Forum
post #1 of 12 Old 02-26-2010, 02:40 AM Thread Starter
chain lube
been looking at the manual for my 700xx and was reading that i should only use sae 80 or 90 oil. and not to use cans of chain lube.
is any one using the sae 80 or 90 oil or are you using cans of lube.
cheers gary
mods to my trx700xx
corsasri is offline
post #2 of 12 Old 02-26-2010, 06:33 AM
I use cans, and I just make sure that they say the lube is O-RING safe.
post #3 of 12 Old 02-26-2010, 07:57 AM
I use chainlube out of the can. Just make sure the chainlube is O-Ring compatible.
post #4 of 12 Old 02-26-2010, 09:57 AM
I use the Honda chain lube and works great!
post #5 of 12 Old 02-26-2010, 11:14 AM
I use PJ1 Blue Label. Safe for O-rings and stays on the chain rather than flying off under rotation like sae 80 or 90 would.
post #6 of 12 Old 02-26-2010, 12:51 PM
Thorsky's Avatar
PJ1 here as well. Works great.
2008 TRX700xx
- EHS Airbox - UNI Filter - Barker Exhaust
- EHS EFI Controller
- RAZRs all around
2008 TRX250EX, Jet Kit, UNI Filter, Airbox mod
2008 TRX250EX, stock for now
2009 KingQuad 750!
Thorsky is offline
post #7 of 12 Old 02-26-2010, 06:55 PM
I use Bell Ray chain lube on mine
2007 Yamaha R1 Charcoal/Black
THREESVTS is offline
post #8 of 12 Old 02-26-2010, 07:43 PM
OzLinc's Avatar
I use nothing......a dry chain collects no dirt. In the the last 5 years of racing I have never replaced a chain or sprocket due to whare.......it's one of those subjects than can be agrued for ever like break-in procedure and what oil to use.
NOTE : I ride in dry conditions, if you get you quad wet and covered in mud I do recomend oiling.......see below
If you do oil your chain spray the oil from above on to the lower run as centrifical force will push the oil into the chain rather than flick off.
OzLinc is offline
post #9 of 12 Old 02-27-2010, 08:02 AM
BiFfMaN's Avatar
I Use Maxima Chain wax
$tock
BiFfMaN is offline
post #10 of 12 Old 02-28-2010, 07:19 PM
airrider03's Avatar
coffee can
I use a parts cleaning brush dipped in 90w.
Put a little 90w in a coffee can and apply it to the chain with a parts cleaning brush.
Cut a hole in the coffee lid and pop the handle thru for storage.
airrider03 is offline
