PC 3 and 5 Maps Uber Thread - Page 17 - Club700XX - Honda TRX700XX Forum
 3Likes
post #161 of 192 Old 01-26-2014, 03:28 PM
Hendogg88's Avatar
It does breathe a lot better to. U can hear it sucking air at idle. I don't see y fci didn't make one for our bikes. A lot of people would've brought it. The 700xx is very choked stock with the small exhaust and intake. With slight mods the bike Really opens up ALOT
Hendogg88 is offline
post #162 of 192 Old 01-26-2014, 05:42 PM
grin
Originally Posted by Hendogg88 View Post
Attachment 6145
I figured out how to post a pic so here it is
yeah thats a duner or drag setup! i will stick to the uni and ehs lid you cant beat it for trails and even doin some mudboggin!
post #163 of 192 Old 01-26-2014, 05:52 PM
Hendogg88's Avatar
I don't ride the dunes anymore. I haven't been there in about 2yrs. I mostly ride the fields by my house or on the road tho. My bike only saw water or mud about 2-3 times and that was by accident. But I never been in the water/dunes with the fci intake and probably won't. I only had the fci for about 5mths and only rode my bike about 3 times since then.
post #164 of 192 Old 08-06-2014, 04:30 PM
Base map needed asap. Pc5, +3mm stroker, stg3 Hot Cam, 10.5:1 Piston, HMF full exhaust, Uni filter, ehs lid w/out side vents.
post #165 of 192 Old 08-10-2014, 08:05 AM
Hendogg88's Avatar
M quick just use this map off the powercommander site-FMF powerbomb header, FMF Q4 muffler, 728cc 10.25:1 piston, Hotcam Stage 1, Stock air filter. This the one I used.
post #166 of 192 Old 07-07-2015, 09:46 PM
Quoted: 143 Post(s)
I just brought a 700r fci intake and customized it.
not finding the fci intake on the web , is there a model number for it ?
cataway is offline
post #167 of 192 Old 08-01-2015, 05:56 PM
Got a PCV now and looking for maps. Been on Dynojet's website and downloaded the maps. Asked me to unzip the file and then it disappears, can't find the maps. What have I done wrong ?
post #168 of 192 Old 08-01-2015, 06:21 PM
Found them on Power commander website.
post #169 of 192 Old 08-01-2015, 10:42 PM
What map are you running? Since I was screwed around at last dyno shop, I just went back with the 009 map which I was running before the stroker. Has to be closer than the 004 map the shop loaded on my pc5 and said it was custom tune!
post #170 of 192 Old 08-02-2015, 10:21 AM
I got someone to set it up on a dyno. I was told they set it to 13:1 all the way through the rpms but the motor is still overheating. Is there a way of seeing the map loaded on my PCV because may change it to the ALBA big bore setting on PC website.
